27 Pages <1234>»
Garth's Build Options
pierre50
#21 Posted : 23 May 2013 19:34:26
Looking very good, nice and clean build mate!
Current Buid:
HMS Victory
Next Build:
Captain Cook's Endeavour Collecting issues
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Garth
#22 Posted : 11 June 2013 08:57:23
Hi Pierre,
Thanks for the positive comments.
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#23 Posted : 11 June 2013 13:28:52
A Great looking build.
Garth
#24 Posted : 12 June 2013 07:04:36
Thank you kindly Jase
Garth
Garth
#25 Posted : 18 June 2013 13:02:48
Chainwales installed.
Garth attached the following image(s):
Garth
#26 Posted : 18 June 2013 13:12:40
Around issue 30, I decided to sort the larger pieces of off-cuts into old part bags. This has proved to be an excellent source of material, especially with Victory Section and SOTS on the shelf!!!
Hope this helps.
Garth
#27 Posted : 18 June 2013 13:21:27
...and more useless information (Hope not)
Having pinned the entire hull using a pair of long nose pliers, and bending countless pins in the process, I was concerned that while pinning the chainwales the pins will rotate in the pliers jaws and mark the finished hull.
I finally thought of doing this modification to my long nose.
I cut a slot into both jaws of an "old" long nose pliers to accommodate the pin head, and filed a grove down the middle. No more twisting/rotating pins - wish I had thought of this earlier!!!
A little late I know, but hope it helps.
#28 Posted : 18 June 2013 13:36:58
Hi Garth
Check this site out. the third one down is called an Artesania Nailer.
These are readily available at most hobby shops. It saves you a lot of grief and bent pins. it help with keeping the pin straight and in line.
http://www.cornwallmodel...ammers_pin_pushers.html
Well done and good looking build you have there.
Garth
#29 Posted : 18 June 2013 15:39:42
Hi Hans,
Thank you for the advice.
Kind regards,
Garth
Garth
#30 Posted : 27 September 2013 07:17:31
Bowsprit complete!!!
z8000783
#31 Posted : 27 September 2013 07:19:39
Groups: Unapproved
Although I'm painting mine (fear mostly) I do love seeing these. Well done.
Garth
#32 Posted : 27 September 2013 07:29:42
Starting to assemble the Gallery. I decided to go the contact glue rout. (I just hate cyno)It seems to have adhered to both the timber and acetate. (And in my case, the acetate sandwiched between the timber and the styrene mullions)
I actually completed this job around two months ago - and all is remains stuck!!! I was concerned that the various materials would de-laminate.
Garth
#33 Posted : 27 September 2013 07:34:18
Hi John,
Thank you kindly.
Garth
#34 Posted : 27 September 2013 21:06:40
BigGrin Looking sweet GarthCool
#35 Posted : 27 September 2013 21:15:46
This is very nice, Id love to try a natural looking build one dayBigGrin Are those 12pdr guns on the poop deck in any reference material, I didnt know they used guns on that deck?, let me know where you saw it - i might put some there too as I have spares.
#36 Posted : 27 September 2013 23:39:38
A build to be proud of Garth, she looks superb....Love Love
Garth
#37 Posted : 28 September 2013 10:25:47
Hi all,
Once again, thanks for all the kind words.
Sorry Steve, the 12 pounders on the Poop are not referenced. I just assembled some spare ones and they are floating around the decks. They will be removed later.
Kind regards,
Garth
#38 Posted : 29 September 2013 17:38:45
Beautiful build there Garth. Nice neat and clean. Well done. Looking great.
Garth
#39 Posted : 26 October 2013 18:10:23
Thank you Hans.
Been working on the gallery for 3 months now - almost done!!! Will upload some pix when I'm done.
Garth
#40 Posted : 04 November 2013 10:42:06
Never fear Garth, the rigging takes forever, many many hours but well worth it Enjoy
Guest (38)
27 Pages <1234>»
This page was generated in 0.280 seconds.
