33 Pages «<1112131415>»
willz buildz Options
#241 Posted : 24 May 2013 08:46:40
Your a true craftsman your work is just stunning Love
#242 Posted : 24 May 2013 08:54:37
Love Love SpeechlessLove Love
z8000783
#243 Posted : 24 May 2013 12:22:44
Groups: Unapproved
Beautiful work willz.
John
willz
#244 Posted : 25 May 2013 16:58:13
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Thanks lads much appreciated
Whilst doing the stern I've been working on the barge, bit here bit there, so here`s an update on the progress, at the mo putting in the oar hole supports, I do these one at a time and let them dry before I cut them down and sand, this method is slow but gives you more control over the positioning of these tiny bliters
willz attached the following image(s):
#245 Posted : 25 May 2013 17:14:11
TERRIFIC!! you are a craftsmanBigGrin All the best Mike
SennaMentalMe
#246 Posted : 25 May 2013 20:30:00
Truly sublime modelling skills on show here Willie and I love watching you work - fantastic stuff sir, we are lucky indeed to have such a talent as yours on this forum and it is very much appreciated!! Drool Love Cool
Well done!! ThumpUpThumpUp
#247 Posted : 25 May 2013 22:45:18
Unbelieveable work by an incredible craftsman and artist..... Love it Willz, simply love it....Drool Drool Drool Love Love Drool Drool Drool
willz
#248 Posted : 26 May 2013 22:26:19
Cheers for the comments lads,.
OK jumped onto the sterns coat of arms (seem to be doing a lot of hopping about at the moment) must say I'm not happy with it at this stage, thought it would be easier the second time round, the problem lies in the smaller scale? although its not that much smaller it is certainly pushing the limits of my experience, I'm happy with the prince of Whales feathers which is the main eye catcher so if I can get the rest of it to a reasonable quality it will have to do, anyhow heres a pic and as you can see still lots of work to do
z8000783
#249 Posted : 27 May 2013 07:09:14
Groups: Unapproved
Have you tried using a microscope?
Amazing work.
John
Taz
#250 Posted : 27 May 2013 07:22:55
Hi willz
Amazing detail,you must have lots of patience and a steady hand BigGrin
Taz
#251 Posted : 27 May 2013 09:24:22
Beautiful work there Willz. Absolutely beautiful.
Glen
#252 Posted : 27 May 2013 13:19:06
dandilion and burdock, The tiny little things that keep the oars in placeLOL LOL
Fantastic build by the way
Roger the Cabin Boy
canoe21
#253 Posted : 27 May 2013 14:59:35
Hi Wilz You are doing a fantastic job on your build the Victory, love the way you have worked out the stearn windows.
Regards Lawrence
sparks
#254 Posted : 27 May 2013 19:19:49
Some unbelievable craftsmanship there Willz Drool
#255 Posted : 27 May 2013 22:47:16
Hi Willz, would be interested to know what kind of tools you use to create such stunning artistic work..... simply beautiful....Drool Drool Drool
willz
#256 Posted : 29 May 2013 02:36:24
Thanks for the comments lads, much appreciated.
OK , the tools I use for carving, first of all I would like to point out that I am a complete novice at carving and my original over scale Victory stern emblem was the first thing I ever carved, so over the next day or so I will print a tutorial on how I tackled the dagger that is to the left of the prince of Whales feathers, and for now heres a pic of the tools I will use in that process
sparks
#257 Posted : 29 May 2013 09:50:47
WOW Willz,
If you're a complete novice, you should take it up professionally, just think what you could do at a larger scale. Wink
As for the tools, I expected something more elaborate, and you even had time to clean your teeth BigGrin
Great stuff.
#258 Posted : 29 May 2013 10:31:21
NOVICEOhMyGod thats stunning work for somebody with experience
Looking forward to the tutorialCool
willz
#259 Posted : 29 May 2013 16:58:32
OK lads on with the tutorial.
First I drew the dagger where it lives on the piece, no need to be flamboyant just a rough sketch, then very lightly I go round it with an ordinary stanley blade slightly oversize, this is done very lightly and repeated till I get the depth required, only put slight pressure on the blade. The next stage still with the stanley blade I scrape away the material from the corners outwards
willz
#260 Posted : 29 May 2013 17:20:15
The next process is to get the shape a little nearer, the finger guard on this dagger has a snake like curve (just to make it easier) so to achieve this I first cut a z shape using a safety razor these are thinner and sharper than stanley blades, so less chance of the finger guard splitting and popping off, never the less you still have to nibble it out a bit at a time
Guest (12)
This page was generated in 3.105 seconds.
