 Rank: Pro Groups: Registered
Joined: 25/03/2010 Posts: 100 Points: 289 Location: derby
Hi Everyone I am a mature female who is rally looking forward to the challenge of building the Victory. I just wanted to introduce myself as I will be needing your help over the next months. So I hope you don't mind me asking silly questions. Good luck everyone Pam
Joined: 18/03/2010 Posts: 121 Points: 359 Location: Waterlooville, Portsmouth. The home of HMS Victory.
Welcome Pam, enjoy. There will be lot of people to help you.
Thanks I will certainly need help !!! Pam
Joined: 21/03/2010 Posts: 170 Points: 549 Location: Lincolnshire
 Rank: Amateur Level 1  Groups: Registered
Joined: 25/03/2010 Posts: 32 Points: 114 Location: ireland
All aboard . im new to this to,  welcome Palm.
Joined: 17/03/2010 Posts: 147 Points: 448 Location: dingwall,highlands of scotland
This site is expanding more every day we're going to have a hell of a forum,it can only get better. CURRENT BUILDS HMS HALIFAX HMS BOUNTY LYDIA EVA(STEAM DRIFTER) MANTUA COASTAL CANON COREL VICTORY CROSS SECTION TAMIYA 1/35 MATILDA MK 2 HACHETTE TIGER TANK DRAGON 1/35 TIGER TANK
And hopefully a lot of new friends I noticed on build the victory someone has built the cannon and painted it. Where do I get the paints from as I also want to paint it as of Trafalgar. Thanks everyone Happy building Pam
Hi Pam i got my paints from Cornwall modelboats on the internet ,they do complete sets CURRENT BUILDS HMS HALIFAX HMS BOUNTY LYDIA EVA(STEAM DRIFTER) MANTUA COASTAL CANON COREL VICTORY CROSS SECTION TAMIYA 1/35 MATILDA MK 2 HACHETTE TIGER TANK DRAGON 1/35 TIGER TANK
thanks Do you paint before you put the model together or after Pam x
Hi Pam, welcome to the forum, and congrats on being the 200th member You paint as you go along.
Some parts can be painted as you go along like the canon and other small parts,larger areas like the hull as their completed, you'll get a feel for it as you progress. CURRENT BUILDS HMS HALIFAX HMS BOUNTY LYDIA EVA(STEAM DRIFTER) MANTUA COASTAL CANON COREL VICTORY CROSS SECTION TAMIYA 1/35 MATILDA MK 2 HACHETTE TIGER TANK DRAGON 1/35 TIGER TANK
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Hi Pam and welcome to the club, the turnout for this model could very well match the crew of HMS. Victory  everyone is raring to go. As to the paints, it is intended that a full kit will be available from Deagostini later on, so hold fast. TIS
Hi everyone i wish issue no 2 would arrive. As I am the 200th member of this great forum do I get a special prize. Can anyone recommend the best glue to use Pam xxxx to all of you
Joined: 22/03/2010 Posts: 66 Points: 180 Location: Horwich, Bolton, UK
pamlupo wrote:...Can anyone recommend the best glue to use Good question because I was thinking of using a SuperGlue instead of the regular wood glue supplied with the kit. On another model I'd started, I used superglue but strengthened joints with a bead of woodglue (where it would not be seen). Oh, and "Hi" Pam! Tom Quentin Tarantino - Hallowed Be Thy Name!
Hi all Anyone out there an expert on glues Would appreciate comments on which glue to use. Pam
Guest (6)
