162 Pages «<5051525354>»
#1021 Posted : 30 May 2013 11:23:07
Hi Alan, she is looking great I agree with Nigel I would keep with the varnish at this stage, also the paint will not stick to the oilBigGrin All the best Mike
#1022 Posted : 30 May 2013 18:27:34
BigGrin nicely done AlanCool
#1023 Posted : 30 May 2013 20:54:45
Hi Alan,BigGrin
Tree nailing looks like the bees knees and I don`t mean knobbly.
LOL LOL LOL LOL LOL LOL LOL LOL LOL
#1024 Posted : 30 May 2013 22:38:52
NMBROOK wrote:
Looking mighty fine AlanBigGrin BigGrin BigGrin great job!Only thing with oil,may cause problems later in the build when trying to glue things to the hull,at least you can scrape varnish off where bonding.
Kind Regards Nigel
Thanks Nigel, appreciated as always....BigGrin BigGrin .. Now decided to go with Ronseal clear matt varnish, thinking 2 coats with a light rub down in between..... Cool Cool .. Thanks again...
#1025 Posted : 30 May 2013 22:40:05
Thanks for the continued support Mike, going to go with clear matt varnish as I want most of the hull to be in natural wood providing my lower planking is good enough.... Cool Cool
#1026 Posted : 30 May 2013 22:41:18
Thanks Andy, I think the effort has been well worth it... little touch up here and there but nothing really noticeable unless you look very closely..... Cool Cool
#1027 Posted : 30 May 2013 22:42:47
delboy271155 wrote:
Hi Alan,BigGrin
LOL LOL LOL .. Don't think you would like to see my knees Derek, they are knobbly...LOL LOL LOL .. Thanks for the kind comments, a long process but certainly for me a worthwhile exercise.... BigGrin BigGrin
#1028 Posted : 30 May 2013 22:55:07
Planking the Lower Hull
.Before starting the lower planking there were some key decisions I made.. I said at the start of the build I didn't like the look of the white hull so decided I would plank the lower hull using walnut strips.. The Sapele is .5mm thick and my walnut is .6mm so gives me a little extra for sanding down. BigGrin BigGrin
Also decided, especially after the experiences of using Bamboo for the first layer that the final layer was not going to have strakes tapering off to a point... that meant the use of droppers and stealers...Cool Cool .. As I have never tried using droppers etc, I really don't know how it will turn out or whether I am doing things correctly so if the more experienced modellers out there see I am going off track then would appreciate they put me on the right track... Cool Cool .. Other immediate concern is determining when half droppers are needed instead of full ones... guess I will find out soon enough..Cool Cool
Finally, I think the lower planking is going to be very slow process to start with until I get a feel for what I'm doing.... Going to do a couple of rows at a time on each side to help ensure I get a balanced look of the two sides... May also do some treenailing as I go along....Cool Cool .. Caulking is also being done between the planks using permanent marker after lightly sanding the edges to prevent bleed.Cool
Well enough of the waffle, here is the pics of my first two rows (almost) and my effort at introducing my very first dropper plank....BigGrin BigGrin .. Comments welcome....
der Gohfelder
#1029 Posted : 31 May 2013 08:35:38
Hi Alan!
A very nice start of th lower hull planking! I´m sure it´s a good decision, I don´t like a white painting too. I want to use the original (basswood?) strips with a clear coating to get a contrast to the upper hull.
Happy planking, BerndBigGrin
btw: I´ll follow you, yesterday treenailing started BigGrin
#1030 Posted : 31 May 2013 10:54:00
Great job Alan, I think that looks perfect.
Admiral Anti Spiral
#1031 Posted : 31 May 2013 11:08:30
lovely work alan! i was thinking of using walnut for the lower wales but i wasn't sure if it'd be dark enough compared to the sapele, so its good to see it be used with the sapeleBigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1032 Posted : 31 May 2013 16:15:22
HiAlan.
Comming along Nicely.
Keep up the good work. IanCool BigGrin
#1033 Posted : 31 May 2013 19:40:56
BigGrin Stunning work on the droppers Alan BigGrin Rgd Martyn
#1034 Posted : 31 May 2013 21:06:44
Hi Alan,BigGrin
The start of the lower planking looks good. Like the use of droppers, makes it look better than planks just getting thinner and thinner.
WTG Cool
#1035 Posted : 31 May 2013 22:38:58
der Gohfelder wrote:
Hi Alan!
Thank you Bernd and am pleased you have decided to treenail.. look forward to seeing how you progress.. BigGrin BigGrin .. Also happy to hear you want to follow me so I'll try and post plenty of pics to assist you...Blink Blink bear in mind I am running on instinct here.... LOL LOL
#1036 Posted : 31 May 2013 22:40:05
Thanks Hans, just hoping the rest of it will turn out as good... time will tell...BigGrin BigGrin
#1037 Posted : 31 May 2013 22:43:38
Thanks Admiral, I didn't want anything too contrasting which is reason I hated the white hull... When this is sanded and varnished I believe I will have achieved the look I'm after....BigGrin BigGrin .. Everything crossed though....LOL LOL
#1038 Posted : 31 May 2013 22:44:53
ian smith wrote:
HiAlan.
Thanks Ian, appreciate it...Cool Cool .
#1039 Posted : 31 May 2013 22:48:07
Thank you Martyn, pleased you like it... Cool Cool
#1040 Posted : 31 May 2013 22:49:11
delboy271155 wrote:
Hi Alan,BigGrin
WTG Cool
Hi Derek and I agree with you, pointy planks simply look awful.... BigGrin BigGrin
Guest (9)
This page was generated in 0.210 seconds.
