162 Pages «<5152535455>»
#1041 Posted : 31 May 2013 22:57:30
Lower hull planking continues and to be truthful I am finding it a lot trickier than I thought...Blushing Blushing . Still running with my instincts here but am sticking to a couple of golden rules namely, allowing the planks to run where they want to lie, no forcing into place and only tapering to half a plank width maximum...Cool Cool .
Getting round the bow has shown it to be a very sharp curve really forcing the plank to rise quite sharply.... more droppers required but decided to change the kind of droppers used and as long as I do the same on the other side then I will maintain a balanced appearance... Blink Blink
The stern requires a very sharp bend in the plank and so far no success, splittin on two attempts.... That is even after soaking the walnut in hot water for 20 minutes...Mad Mad Mad .. will have another attempt tomorrow....Cool
Ok, now the pics.....Huh Huh , not sure if it's right but it is working....BigGrin BigGrin
NMBROOK
#1042 Posted : 31 May 2013 23:49:34
Hi Alan
That looks fantastic!BigGrin BigGrin
Don't tell the wife but I stick the end to be curved in the kettle and boil three timesLOL LOL LOL LOL .I have managed a 10 mm radius on 2mm thick walnut using this technique!
Kind Regards Nigel
#1043 Posted : 01 June 2013 00:01:54
NMBROOK wrote:
Hi Alan
Kind Regards Nigel
Thanks Nigel for the very high praise, appreciated.... BigGrin BigGrin .. Will try the kettle tomorrow and see how it goes, the stern plank requires an almost 90 degree bend so may have to do it in stages..... here we go with the experimentation again....LOL LOL .Thanks again.
#1044 Posted : 01 June 2013 00:06:37
Hi Alan.
That's looking brilliant as ever, especially the stealers and according to one of my (now very old) 'how to do it' type books, the type of joints you're putting in are exactly right! Cool
Apparently that first one you did is called a 'Joggle Plank'
As for the sharp plank on the stern, if all else fails you could try the nasty alternative: Household Ammonia. The same book as above, "Planking Ships" by Richard Mansir (Moonraker Workbook Number 1) put me on to using it on the Grimsby which was single planked in double thickness hardwood planks! And it worked really well, as long as you have good ventilation. At the time I was building her in a workshop built on the end of my Dad's garage so ventilation was no problem - frost bite in winter was though! I soaked the planks half a dozen at a time in a laboratory glass thingy, essentially a huge 100ml test tube with a flat base and you could almost tie the planks in knots after a good soak.
If you have a garage or garden shed I would recommend soaking a couple of planks overnight outside and just bring them in when you are ready, leaving the ammonia itself outside. Once removed from the ammonia you'll have about 20 minutes to bend them into place and then just let them dry off in situ. I did the whole hull of Grimsby in that fashion, pinning the planks in place when wet then removing them again once dry and PVA-ing them back in place. It's nasty stuff admittedly, but equally, very effective!
Hope you can sort it out, and keep up the great planking!
NMBROOK
#1045 Posted : 01 June 2013 00:07:23
NMBROOK wrote:
Hi Alan
Kind Regards Nigel
If you are doing it on the slyLOL LOL change the water afterwards,walnut will turn it brownLOL LOL LOL LOL LOL LOL
Kind Regards Nigel
court orchard
#1046 Posted : 01 June 2013 00:22:22
NMBROOK wrote:
NMBROOK wrote:
Hi Alan
Kind Regards Nigel
Kind Regards Nigel
Probably safer to get a six quid kettle from Tesco, then risk the wrath of SWMBOLOL LOL
Great work by the way Alan.
PS Ammonia works but will bleach the Walnut.
#1047 Posted : 01 June 2013 09:29:19
BigGrin Or buy a cheap baby sterilizer/steamer like Jase recommended and Delboy got for around a squid of flea bay and looking a treat Alan
SandyM
#1048 Posted : 01 June 2013 11:44:50
Hi Alan,
She's looking Good, if your going to ammonia remember it will lighten the walnut.
Personally I see which way the strip want's to bend, mark, soak overnight in water wipe off the excess water glue and clamp, because its wet the white glue gets a very good bond. It works for my 2mm thick walnut.
Sandy
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
court orchard
#1049 Posted : 01 June 2013 12:30:23
That's a good point that Sandy makes, in that normal strip wood will bend much better one way in preference to the other. This is because of the way it was cut in reference to the grain, one side will start to split away, much more readily. I always test bend my strips and mark the side that will form the inside of the curve. I mention this as the Bamboo doesn't have a preferential bending direction and now we are moving to other strip woods it's important to be aware of this.
#1050 Posted : 01 June 2013 12:59:06
Thanks for pointing out the bit about ammonia lightening walnut boys, I never knew that! The Grimsby's hull planks were a mahogany coloured wood possibly Sapele? and the ammonia didn't alter the colour at all.
Sorry Alan! Blushing
#1051 Posted : 02 June 2013 00:08:31
Plymouth57 wrote:
Hi Alan.
Hi Robin, thanks for the info.... Not sure I would want to go down the route of using Ammonia, have used it before and I think I was on a high for about a month,,,, LOL LOL LOL ... Think I have got the problem solved, simply a good old soak for a couple of hours and then when I started the bending process I resorted to steam from the kettle... Couple of planks laid and bent, now secured wet to the hull waiting to dry... will have a look tomorrow and glue in place if everything looks ok.... BigGrin BigGrin
Have to say I am now a little confused.... the way I cut the planks I called droppers which is what I thought they were yet you have called them stealers... I thought stealers were really used on the stern to increase the number of planks and droppers to reduce..... BigGrin BigGrin .. Now a confused puppy but at my age it's easy to get confused...LOL LOL LOL
Thanks again...
#1052 Posted : 02 June 2013 00:10:36
NMBROOK wrote:
NMBROOK wrote:
Hi Alan
Kind Regards Nigel
Kind Regards Nigel
LOL LOL LOL .. Thanks Nigel but I think am safe, the wife hasn't seen the kettle for quite a while now.... I could grow penicillin in there and still get away with it.....LOL LOL LOL
#1053 Posted : 02 June 2013 00:12:08
court orchard wrote:
NMBROOK wrote:
NMBROOK wrote:
Hi Alan
Kind Regards Nigel
Kind Regards Nigel
Thanks Andy, amonia is out as I certainly don't want to bleach the Walnut.... Thanks for the heads up... Cool Cool
#1054 Posted : 02 June 2013 00:13:14
Thanks Andy, will have a look and see what I can find.... Cool Cool
#1055 Posted : 02 June 2013 00:15:15
SandyM wrote:
Hi Alan,
Sandy
Thanks Sandy, appreciate the advice.... Tried as you suggested, soaked for a few hours and bent using steam from the kettle.... think I have the problem solved..... Cool Cool .. Thanks again..
#1056 Posted : 02 June 2013 14:20:12
Hi Alan!
Er, yes, droppers and stealers! I was looking at the illustration of the stern in that book! You're absolutely right! Blushing
That's why I generally call all the different bits planks!!! Blushing Blushing
Glad you sorted out the bending of those ......what were they called again, Oh yes!..... planks!BigGrin
Keep it up.
der Gohfelder
#1057 Posted : 02 June 2013 15:38:40
Hi Alan!
Do we see some new pics today with your progress? I think planking the stern is a little bit tricky BigGrin
Regards, Bernd
#1058 Posted : 02 June 2013 17:36:20
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Hoping to post later today Bernd and I have to agree, the second planking especially round the bow and stern requires more patience. I have found it tricky but think I am getting there... Cool Cool .. No blue words used....LOL LOL LOL ...YET!..LOL LOL LOL
#1059 Posted : 02 June 2013 19:20:07
LOL LOL My model making skills have definately reached a new high....Blink Blink .. Maybe I should be known as The Cobbler of the Seas.... LOL LOL
der Gohfelder
#1060 Posted : 02 June 2013 19:39:38
Hi Alan!
Me too BigGrinBigGrin (just finished row 14)
Regards, Bernd
Guest (9)
This page was generated in 0.423 seconds.
