Other steam train scale kits Options
Heinzy
#1 Posted : 03 June 2013 13:14:21
I wonder if any of you guys can help
I'm after building a steam train for my dad for his birthday (november)
My grandad, his dad, used to work on steam trains in his younger years and sadly my grandad is no longer with us.
My dad kept all of his steam train memorabilia, from LNER i.d plates to collections of cigerette cards
I thought it would be a nice touch to add to this collection with a personally built replica, I really like the look of the D51, but due to the duration of the part build, it would have to be a birthday present of the future!
Also I think I would like a replica train from british soil
I've searched and searched with no joy Crying
All I can seem to find is working trains for track kits
It doesn't have to be the same scale as the D51, but the larger the better really
Any help would be greatly received
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
#2 Posted : 03 June 2013 13:30:51
Hi
you don't give a preferred medium i.e.plastic, metal etc. but Trumpeter do some 1/35th scale steam engines in plastic kits you may be interested in.
Trumpeter steam engine
Engine 2
court orchard
#3 Posted : 03 June 2013 13:36:50
Hi Heinzy,
These are supposed to be good and the motor units are optional.
They are O Scale, so about half the size of the D51
http://www.djhmodelloco.co.uk/djh-model-loco-kits/
Or Occre do some at 1/32
http://www.cornwallmodelboats.co.uk/acatalog/OC54003.html
Heinzy
#4 Posted : 03 June 2013 14:05:26
Thats great thanks guys
Is there much difference in the finish between the 2 material kits?
I was reading that the metal kits require soldering Confused
It's been a while since I soldered last, and am a little worried I'd fudge the kit up!
The Brawn Build
The MP4/4 Build
#5 Posted : 03 June 2013 15:43:03
BigGrin Hi Heinzy
You could try Tower Models they sell a lot of brass/white metal engine kits but be warned some are serious money, they also offer a painting service and I think a building service [Not sure on the last bit] but there a friendly bunch in there so perhaps a phone call may help you decide what's a good project. The link to the website is below
http://tower-models.com/
Hope this helps
Heinzy
#6 Posted : 03 June 2013 16:56:07
Thanks Andy ThumpUp
The Brawn Build
The MP4/4 Build
spikee
#7 Posted : 05 June 2013 01:06:03
Hi Heinzy.Sounds like a great idea.
As mentioned before the only plastic kits Im aware of are the 2 Trumpeter german trains from WW2 in 1/35,and I seem to remember Airfix did a couple of really small kits about 40 years ago!
Your other choice is etched brass/white metal construction in either gauge 1 (also know as "live steam" and huge amounts of money!) or 'O' gauge which is about 17"-18" long for a typical loco which is a nice size.
You dont need to make them motorised,as they dont come with motors couplings or wheels (some dont even have sprung buffers included)and I would think you could superglue a lot of the loco together if its only for display IF it has a cast metal boiler and not a brass one,as this would have to be rolled and soldered I would think.
You usually buy the kit,then go to Slaters plasticard and buy the wheels and couplings from them so dont forget to add this to the cost too (although DJH do offer these as options to buy on their website).
Kits....theres DJH as mentioned,expensive,not the most detailed kits out there but easy to build (and they do fully built and painted ones if youve deep enough pockets).They could be superglued together as the boilers are cast in one big lump so no having to roll the sections of brass boiler and soldering them together.
Then theres David Andrews kits,which are really nice to build,but soldering is a must as is rolling the boiler!But they are the cheapest out there I think.
http://www.locomotivekits.com/
The top of the line is ofcourse Martin Finney kits which are incredibly detailed,but again soldering and rolling the boiler are needed.But they are beautiful kits if not easy to make.
http://website.lineone.net/~cbwesson/7mm.htm
Theres also Piercy kits which are hyper detailed (see DJH website),but I think it MIGHT be possible to build an A4 (eg mallard) with superglue only as again its a cast metal boiler.But you may have to reinforce the joins of the tender sides,and the cab would have to be soldered up as I cant see another way of doing that,but everything else could be glued thinking about it.
As the running gear is all bolt together so no solerdering there,as as its static I dont see a problem.
But dont let soldering put you off any kit,as its easy to do,theres lots of tips and guides online for soldering locos up and what tools etc are needed.
But as the previous poster said,give Tower Hobbies a phone call and they will help you out,as customer service really is fantastic,service top notch and theres nothing they dont know when it comes to O guage locos.
Jon
Heinzy
#8 Posted : 05 June 2013 13:14:58
Thanks Spikee thats great
I didn't actually realise the number of loco's available
I might try and dig up a little history of my Grandads time on the trains
See if I can find out what one's he worked on
Would be a great present to give my Dad a scale model of one of the machines my Grandad was so keen on
Better get my research hat on!
You've all been a great help thanks again
I'll keep you all posted with what I dig up BigGrin
The Brawn Build
The MP4/4 Build
This page was generated in 0.141 seconds.
