21 Pages <12345>»
My Victory build Options
yzwong
#41 Posted : 12 May 2013 16:46:13
Thank Mr T , Thank Mike , Thank Alan
Current build - D51 locomotive
Completed building the H.M.S Victory
Now collecting the Senna McLaren MP4/4
yzwong
#42 Posted : 15 May 2013 17:33:33
More on the hull planking
yzwong attached the following image(s):
#43 Posted : 15 May 2013 19:09:34
BigGrin looking goodCool
petpole
#44 Posted : 15 May 2013 20:01:02
Nice build yzwong.
Keep up the good work.
Peter
BigGrin BigGrin BigGrin BigGrin
#45 Posted : 15 May 2013 23:16:28
Hi yzwong, really nice to see the old girl starting to take shape..... BigGrin BigGrin ..Very nice work there.....BigGrin BigGrin
yzwong
#46 Posted : 22 May 2013 16:08:03
Nice thank to all of you guys.
Gun ports cont.....
NMBROOK
#47 Posted : 22 May 2013 17:35:52
Exceptionally clean and accurate workBigGrin BigGrin
Kind regards Nigel
#48 Posted : 22 May 2013 21:56:00
Impresive work Yzwong, very neat and tidy building.... Very well done to you.... BigGrin BigGrin
yzwong
#49 Posted : 30 May 2013 15:26:34
Thank Nigel , Thank Alan
My build cont....
#50 Posted : 30 May 2013 18:15:03
BigGrin Hi
Very tidy and neat job there
yzwong
#51 Posted : 11 June 2013 15:31:25
Thank Andy
More on the gunport
yzwong
#52 Posted : 13 June 2013 16:22:50
Hi , can anyone help ??????????
Which issue or how can i obtain this card template that use as a guide
Below is a picture of it in issue 31.
Lucien
#53 Posted : 15 June 2013 12:49:17
The template is made in issue 24.
Greetings Lucien
yzwong
#54 Posted : 15 June 2013 15:07:09
Hi , Lucien , Thank for your reply but are you sure is issue 24.
I had check and can't find anything about card template.If possible can you post a picture of it. Thank again
Lucien
#55 Posted : 16 June 2013 06:49:29
Hi Yzwong.
I checked again and on the Belgium Deagostini website the template is made in issue 24.
(See this link)
If you look at the official build here on the website it is also made in issue 24 (see this link, post nr.6).
Look trough your subscription magazine again, it should be there.
Greetings Lucien
z8000783
#56 Posted : 16 June 2013 08:51:02
Groups: Unapproved
Looks great. Will look wonderful when you sand her down. Are you staining, painting or coppering?
John
yzwong
#57 Posted : 16 June 2013 12:52:30
Thank John,
As for her , I wait until complete planking the hull first.
yzwong
#58 Posted : 16 June 2013 13:05:01
Hi, Lucien , Thank again for your quick reply
I think I know what is wrong. It's the issue problem but anyway I think I can print out from your link and hopefully the template is the same size.
Here is some picture of my issue 24.
Lucien
#59 Posted : 16 June 2013 15:07:26
Hi Yzwong
It does seem that your issues differ from ours.
I did a quick check and your issue 24 is the same as my issue 23.
So it could be the template is in your issue 25.
Might be a good idea to look through your issue's from 25 and above.
It cant be very far off and should be somewhere in the magazine.
In case that you cant find it, i took the measurements for the template.
So that when you print it out you can check if it is the right size.
Greetings Lucien
yzwong
#60 Posted : 17 June 2013 05:32:47
Hi, Lucien , thank you very much
As for the card template , I Had double check issue 20 - 32 and there is nothing about it.
I already print out a copy of the template and the measurements is smaller varies from 2mm to 5mm in size. I think some enlargement printing has to be done.
Anyway I can still go on with my builds without using the template.
Again thank for your time and effort
YZwong
21 Pages <12345>»
This page was generated in 0.327 seconds.
