Hi Andre I used a tooth pick and super glue and it worked like a dream. As per usual you only have a few seconds to adjust, but if you size and align with a few guiding lines it works well. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro  Groups: Registered
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Thanks Pierre and Hans for the advice on the glue. An american co-worker is bringing me Formula 560 glue to use. Below are some random photos of what I have done so far.    I will try to get the gallery and rest of the deck finished when I am home at end of Feb. Regards Andre Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Joined: 11/09/2011 Posts: 227 Points: 677 Location: Heidelberg South Africa
Looking great Andre! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Thanks Pierre 14 days to go and I will be home and the shipyard will be open. Cannot wait to continue building. Question: What is the diameter of the wire used on theyards for the footrope? Regards Andre Current Build: HMS Victory
Built: HMS Bounty
Not to sure, everything packed away, we're moving (AGAIN) I think it's 0.5mm. Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Good Day All A belated mail and thanks for the comments. I have completed the stern galleries.  [/URL][/img] Have completed the bow and made the planking wider so as to fit the ornaments. A problem that was identified by the forum members at the beginning of the build.  [/URL][/img] I remade the platform and ladders from the poop deck to the main deck. will finish them off when the shipyard opens in 12 days. the reason for this was that the ladders would run into the canons and I was not happy with it.  [/URL][/img] Finally, an overall view of the Victory. After this build, I will not be painting anymore as I have a problem trying to paint a straight line.  [/URL][/img] Regards to all Andre Current Build: HMS Victory
Built: HMS Bounty
Cannot seem to upload the photos with photobucket. Well back to the drawing board to see what went wrong or what has changed. Andre Current Build: HMS Victory
Built: HMS Bounty
Looking good there Andre. sorry to see you have a problem with straight line painting. I have quoted a piece from DaDokta wherby he gives a little advice for bleeding and straight lines. "I guess you already know that - but when masking the waterline (or any line) with tape, you first should paint a thin coat of the colour, you are masking, along the tape. When dry, you can paint the other colour, which now can`t run under the masking tape. E.g. you first paint the copper part - then you mask the waterline. Then you paint a thin coat of copper along the tape on the side, where the black paint will be. And then, when dry, you apply the black coat." I hope this helps. Cannot talk from expereience as i am using natural colours and varnish. It does make sense and sound logical. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Baie mooi! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Thanks Hans and Pierre Will be posting photos shortly as I am up installing the masts to permanently attach the shrouds. I have a question: are anyone of you two going to build the pikes that fit onto the fore and main masts. My reason for asking, is that I cannot find 1.5mm tape so I will not be going that route. Regards Andre Current Build: HMS Victory
Built: HMS Bounty
Hi Andre Good build you have there. Nice clean lines. yes I did put the pikes on. I struggled a little but eventually got there. I also could not find the micro tape so took a piece of dowel about 50mm long, I think it was 12mm, drilled a 10mm hole down the centre and then sliced them the wanted size. Drilled holes for the pikes and superglued them in place. I will have to check the sizes to night and come back to you. Watch this space. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Good Day to All I was trying to attach the Hammock frames as per magazine instruction and found that it was very difficult to keep the frames upright, insert the rods and sew on the nets. I the made a jig where I could do it all at once. The first step was to measure the length where a hammock frame would go, divide the amount of frames into the length, mark the distance between the frames on a piece of wood (19mm thickness). cut slots on the markings, install the frames, insert the rods (glueing them in place) and finally attaching the nets. The following is a photo of the jig I made. Do not worry about the frame that is at an angle, when fitted to the ship it is vertical.  So far, I have attached all the masts, fitted the shrouds and connected the lower mast shrouds to the chainwales.  The shipyard is now closed until August when I return home from Afghanistan. I will then continue with tensioning the shrouds and connecting the next set of shrouds and then follow the next step as per the magazine. Cheers to all. Andre Current Build: HMS Victory
Built: HMS Bounty
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Your Victory is looking great Andre, nice work
Thanks for all the comments. I have not done anything further on my build due the changing of work as well as location. I am now in Mali and will only be home mid November. Regards Current Build: HMS Victory
Built: HMS Bounty
Looking good Castos, see you November! Regards Pierré Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Looking fantastic!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Good work Castos. Looking forward to your progress pix when you get back. Regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
very nice build castos. k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Very nice indeed Castos, respect.... Regards Alan
