Painting and/or spraying ? Options
#1 Posted : 13 June 2013 20:56:32
Hi All,BigGrin
As a newbie, could somebody put together a bit of a Tip List for painting and spraying.
Things like masking ideas, paint thinning and brush work.
I understand that these sort of things can only be generalised, but some ideas of what dry brushing can achieve, different paint mixes etc.
I have no problem with experimentation however long it takes, but some ideas of where to start out would be of benefit.
Thanks in anticipation BigGrin
#2 Posted : 13 June 2013 21:27:26
hi del there have been several tutitions on this subject by jase,apurchase,and others,just use the search at the top of the page.also utube do many.
#3 Posted : 13 June 2013 21:42:08
Cheers Karl,BigGrin
That info helps a lot, as somewhere to start searching.
Many Thanks
This page was generated in 0.114 seconds.
