10 Pages «<23456>»
AK's Sovereign Build Options
#61 Posted : 15 June 2013 12:52:48
BigGrin Looking dooog AndyCool
Admiral Anti Spiral
#62 Posted : 15 June 2013 14:59:20
Coming along nicely AndyBigGrin keep it up
Processing - Progressing
Previous builds: HMS Victory
claret
#63 Posted : 16 June 2013 10:53:08
Hi Andy,
Lovely planking. Keep up the good workBigGrin
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
court orchard
#64 Posted : 16 June 2013 14:32:46
BigGrin Looking goood AndyCool
Thanks Andy, slow but rewarding.BigGrin
court orchard
#65 Posted : 16 June 2013 14:34:15
Thanks Admiral, taking my time on this bit, no where to hide anythingLOL
court orchard
#66 Posted : 16 June 2013 14:35:17
claret wrote:
Hi Andy,
Claret
Thanks Claret, yours is looking pretty good tooThumpUp
court orchard
#67 Posted : 16 June 2013 15:01:27
Now with issues 38+ I'm able to step things up a bit.
Firstly I fitted the Transom supports and Transom, I thought I needed these fitted for the planking measurements, but in fact I didn't.
Care needs to be taken fitting the supports, as their natural position is to sit square to the Back Wall of the Stern (#50) but they need to sit at an angle, so they are in line with the slots on the side pieces. I took Mr T's advice and fitted Support Blocks under the top piece. I also had trouble gluing the Transom down, as it curves a the base but is flat at the top. I found the Ply was too thin to clamp safely, so I nailed it in place.
I then dry fitted the remaining pieces, marked the limit of the planking and also added a line for the start of the Black section. I did this with a Red Pen, so I wouldn't get confused with all the other lines that I have marked on the HullBlushing
Then I cut and tapered Sapele planking to finish at this line.
Then I switched to 0.5mm Black Boxwood Strip for the rest of the planking, this is Marquetry Wood and is Black all the way through, so can be sanded etc. Thanks again to Nigel for the 'heads up' on this.
NMBROOK
#68 Posted : 16 June 2013 15:11:03
Lovely work AndyBigGrin BigGrin .The black boxwood looks amazing!!I have a lot of work to do before I fit mine to the upper hull.
Kind Regards Nigel
#69 Posted : 16 June 2013 22:42:34
Stunning Andy, love the black boxwood..... gives a beautiful finish.... Nicely done m8... BigGrin BigGrin
court orchard
#70 Posted : 17 June 2013 01:17:40
Thanks again Alan, the Boxwood is lovely and as black as night right the way through, highly recommended.
court orchard
#71 Posted : 17 June 2013 01:21:55
Kind Regards Nigel
It looks even better in the flesh, great to work with too. Solid Colour or should I say lack of ColourLOL.
court orchard
#72 Posted : 17 June 2013 13:48:04
Black Boxwood Planking completed.
NMBROOK
#73 Posted : 17 June 2013 18:26:24
She looks beautiful AndyBigGrin BigGrin When you sand the boxwood it goes a funny grey,but will return to as it was when you put finish on.Since buying the black boxwood,I have bought all sorts form OM and am mightily impressed with their products.Did you order enough black for the deck bulkheads?
Kind Regards Nigel
Admiral Anti Spiral
#74 Posted : 17 June 2013 19:37:23
wow beautiful work, i love the look of the black boxwood, great work Andy BigGrin BigGrin
court orchard
#75 Posted : 17 June 2013 23:52:16
Thanks Admiral, I can recommend the Boxwood.
#76 Posted : 17 June 2013 23:57:04
Stunning Andy, simply stunning.... BigGrin BigGrin .. A little to late for me to consider the boxwood for this build but have banked the idea for other builds I have storing away..... Blink Blink .. By the looks of things I think you are another who will end up with one beautiful lady for display..... BigGrin BigGrin ..Love your work....
#77 Posted : 18 June 2013 09:59:33
Lovely job there Andy, looking forward to the next set of pics.
court orchard
#78 Posted : 24 June 2013 08:51:53
Thanks Hans, slow work at the moment.
court orchard
#79 Posted : 24 June 2013 08:55:03
Kind Regards Nigel
I agree Nigel, OM are very good and yes I now have enough for the Bulkheads.LOL LOL But I think I need some more Maple.Crying Crying
stujue
#80 Posted : 24 June 2013 09:10:53
Hi Andy
your model looks stunning, BigGrin BigGrin , can i ask where you got your black boxwood from, os it the same size planks as the saple
cheers stu
Cheers Stu
10 Pages «<23456>»
This page was generated in 0.479 seconds.
