How are you finishing the hull? Options
RobT
#1 Posted : 15 June 2013 20:34:19
Just bouncing some ideas around here.
I'm a little undecided on how to finish the hull. The magazines suggestion of white just looks too harsh for me. I was thinking maybe of using the same burgundy that the launch uses.
What options are you guys considering?
joewb10
#2 Posted : 15 June 2013 21:01:58
Not really thought about it but I would be interested in thoughts on other than white. Its probably the hardest colour to get looking good. especially since I'll be brush painting it.
#3 Posted : 15 June 2013 22:57:06
I used what is termed as an 'heirloom white' for the very same reason, which is an off white.
RobT
#4 Posted : 16 June 2013 00:01:26
Is that a spray paint?
NMBROOK
#5 Posted : 16 June 2013 01:40:17
Hi Rob
The legendary Keith Julier always used to use Dulux Barley white.You used to be able to buy it in tester pots,don't know if that is still the case.
Kind Regards Nigel
court orchard
#6 Posted : 16 June 2013 02:54:03
Personally I'm not a fan of the White Hull look. So I am going to go for a natural Wood finish of Maple.
In the days before Copper Sheathing Hulls were painted with various concoctions to prevent Fouling with Weed, Barnacles and to reduce Ship Worm damage. The palest of these 'White Stuff' was a mix of Sulphur, Whale Oil and Pine Resin so would have been a kind of pale dirty brown rather than any sort of white. It was called 'White Stuff' to distinguish it from 'Black Stuff' which was Tar based rather than a reference to it's colour.
#7 Posted : 16 June 2013 09:53:05
It is indeed, is a satin finish and in a 400ml big can, and is about the same colour as the Barley white mentioned by Nigel..
http://www.rustoleumaero...nfo.php?products_id=219
Also available via ebay
They also do an aerosol primer to suit..
This page was generated in 0.283 seconds.
