13 Pages «<45678>»
Delboy271155 Sots Options
#101 Posted : 18 June 2013 09:57:12
Good job, Derek, well done.
#102 Posted : 18 June 2013 18:31:11
BigGrin Nice work Derek keep the pics coming ThumpUp Rgd Martyn
#103 Posted : 18 June 2013 19:20:02
Looking good Derek and you did the right thing by adding the extra plank...Cool Cool .. As long as you are above the ribs then you will be fine... Well done m8....BigGrin BigGrin
Hi Alan,BigGrin
Thanks for looking in, it`s onto side two tomorrow as I`ve got a day offLaugh Laugh Laugh
#104 Posted : 18 June 2013 19:24:22
NMBROOK wrote:
WTG DelBigGrin BigGrin BigGrin .As Alan said will sand down well,but don't forget about the hull profile post.
Kind Regards Nigel
Hi Nigel,BigGrin
Thanks for looking in, the sanding could be fun but got to plank top of second side tomorrow.
Could you expand on the "hull profile post" not sure what you are getting at, just got home from a 13 hour day at work and not fully tuned in yet.
Confused Confused Confused Confused Confused
#105 Posted : 18 June 2013 19:25:38
Hi Hans,BigGrin
Thanks for looking in and kind comments.
#106 Posted : 18 June 2013 19:27:36
Hi Martyn,BigGrin
Thanks for looking in and kind comments, will update when side two is up to the top.
NMBROOK
#107 Posted : 18 June 2013 19:35:35
delboy271155 wrote:
Kind Regards Nigel
Hi Nigel,BigGrin
Hi Del,it was the post that led you to find the distorted rib at the stern,it shows you the common depression to look out for as ideally it wants filling before second planking.
Kind Regards Nigel
#108 Posted : 18 June 2013 19:47:49
NMBROOK wrote:
delboy271155 wrote:
Kind Regards Nigel
Hi Nigel,BigGrin
Kind Regards Nigel
Cheers Nigel,BigGrin BigGrin
That jogged the old grey matter into gear and yes I`ve got the suitable filler to hand already.
Many thanks for the memory jog Cool
#109 Posted : 21 July 2013 18:33:23
Hi All, BigGrin
Well, I`ve found time for an update. Delay due to pressures of work and wanting to get on with second planking, unfortunately the pressure of work took front of stage (can`t wait to retire Crying ).
The pics will explain what`s been going on, suffice to say it ain`t all been plain sailing as you will already probably know LOL LOL .
Pics will show: Gun port marking
Gun port cutting Cursing
Second planking at various stages (one side only so far)
Thanks to Gandale (Alan), as I have started lower hull 2nd planking and his close up pics have been invaluable.Cool Cool
Well that`s it for now, will update again asap BigGrin BigGrin
#110 Posted : 21 July 2013 20:02:04
ThumpUp Bril work delboy keep it up BigGrin Rgd Martyn
NMBROOK
#111 Posted : 21 July 2013 23:14:44
Great work DelCool Cool .No updates for a bit,then WHAMLOL
Kind Regards Nigel
#112 Posted : 21 July 2013 23:17:48
Lovely work on the planking Derek, very very well done to you.....BigGrin BigGrin .. It may be a slow process but the results you are getting are very much worth your efforts so keep it going....BigGrin BigGrin
Admiral Anti Spiral
#113 Posted : 21 July 2013 23:57:30
Lovely work on the planking and gun ports del, gun ports are a pain but you seemed to of done well with themBigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
#114 Posted : 22 July 2013 10:29:57
Good job Derek, looks like your coming on in leaps and bounds.
claret
#115 Posted : 22 July 2013 11:16:52
Hi Derek,
That is looking very nice indeed. Keep up the great work.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#116 Posted : 22 July 2013 18:22:35
Hi martyn,BigGrin
Thanks for looking in and the kind comments.
#117 Posted : 22 July 2013 18:30:17
Kind Regards Nigel
Hi Nigel,BigGrin
Well it`s like this, had loads of work on and fitted in as much time on the build as possible and overlooked the diary. Then SWMBO stuck her two penny worth in "you spend every minute blah blah blah **** blah blah", so hence the update just before i ducked the missiles LOL LOL LOL
So, thanks for looking in and the kind comments.
#118 Posted : 22 July 2013 18:38:19
Hi Alan,BigGrin
Thanks for looking in and the kind comments. Just glad to see the back of the bamboo planking (even though there are a few places for it yet).
I am now really enjoying the progress, but still taking the second look before I take the plunge on each stage.
#119 Posted : 22 July 2013 19:03:39
Hi Admiral,BigGrin
Thanks for looking in and the kind comments. You are spot on with the the ports being a pain (especially in bamboo). My method was to use a dremel with a small round reamer bit. With that I took out the bulk of the scrap, then took a new blade (8 in total) to do the trimming up to the markings.
I`m now really enjoying the second planking layer and looking forward to getting into some of the finer details.
#120 Posted : 22 July 2013 19:05:21
Hi Hans, BigGrin
13 Pages «<45678>»
This page was generated in 2.607 seconds.
