7 Pages <1234>»
Stu,s build Options
NMBROOK
#21 Posted : 21 June 2013 00:45:01
Beautiful work on the hull StuBigGrin BigGrin Good luck with the gunports.
Kind Regards Nigel
stujue
#22 Posted : 21 June 2013 09:09:15
thanks Alan, ill take a good look before i start the gun ports, i suppose having to put the new bathroom in has done me a favour and let me fall behind so i can cash in on the advice. its really appreciated though.
cheers Stu :-)
Cheers Stu
stujue
#23 Posted : 21 June 2013 09:10:23
thanks for having a look nigel. i appreciate the encouragement
cheers Stu
Cheers Stu
stujue
#24 Posted : 21 June 2013 18:37:59
Ive now lined off the top off the hull. i intend to cut these off later on after all the gun ports are cut as it looks like some of them come close to the top edge.
Cheers Stu
Cheers Stu
stujue
#25 Posted : 21 June 2013 18:44:50
Ive now temp pinned a piece of bamboo to the hull so i can mark all the lower gun ports. im going to use a 12mmx13mm template to draw in the gun ports. ive made this dead size and then ive put a small chamfer on the inside edge the intention is that this will allow for the thickness of the pencil line and i will remove the line when final filing to size.
cheers
Stu
Cheers Stu
#26 Posted : 21 June 2013 22:52:14
Hi Stu, very clean and precise looking.... very well done... BigGrin BigGrin
SandyM
#27 Posted : 22 June 2013 00:22:53
Hi Stu, what can I say that has not been said already, very nice build.
Sandy
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
stujue
#28 Posted : 22 June 2013 08:33:40
thanks Alan and Sandy. I appreciate you looking inBigGrin BigGrin
Cheers Stu
stujue
#29 Posted : 22 June 2013 12:24:56
Well thats the gun ports lined off. Im now waiting for some courage to cut into the hull.Crying Confused Crying Confused Huh Huh
Cheers Stu
Admiral Anti Spiral
#30 Posted : 22 June 2013 15:20:42
a smooth hull always looks great, great work stu! BigGrin
Processing - Progressing
Previous builds: HMS Victory
#31 Posted : 22 June 2013 16:14:03
BigGrin Hi Stu just take your time with the first one and it all becomes a lot easy with the restBigGrin Happy building . Rgd Martyn
stujue
#32 Posted : 22 June 2013 17:11:08
Thanks Admiral and Martyn. appreciate you taking a look. BigGrin BigGrin
Cheers Stu
#33 Posted : 22 June 2013 23:09:40
Hi Stu, know how you feel.... I had my heart in my mouth when it came to actually cutting that first port out.... BigGrin BigGrin .. Take your time with it and I'm sure it will work out just nicely.... BigGrin BigGrin
stujue
#34 Posted : 23 June 2013 16:14:01
Finally plucked up the courage to cut into the hull and now ive got half the port side gun ports cut out. BigGrin BigGrin
Cheers Stu
stujue
#35 Posted : 23 June 2013 16:18:20
ive used a template for the gun ports, and keep trying it in then filing a bit then try again, this way i can make sure all the ports are the same size.
cheers
STU
Cheers Stu
NMBROOK
#36 Posted : 23 June 2013 18:18:47
That's mighty fine work StuCool Cool
Kind Regards Nigel
stujue
#37 Posted : 23 June 2013 20:30:35
thanks Nigel, that means a lot coming from yourself. ive been watching your diary, your producing some great work. a pleasure to watch it come together.
thanks stuBigGrin BigGrin BigGrin BigGrin
Cheers Stu
claret
#38 Posted : 23 June 2013 20:58:56
Hi Stu,
Looking good!
Daunting to start with, but your doing a great job.
claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
stujue
#39 Posted : 23 June 2013 21:15:55
thanks claret. Ive been watching your build closely, can i ask how you got the caulking effect on the upper second layer of planks, i wasnt going to tree nail as its my first ever build, but you seamed to have nailed it (excuse the pun) might have a go now seeing yours.
cheers Stu BigGrin BigGrin
Cheers Stu
#40 Posted : 23 June 2013 22:55:26
Beautiful work Stu, sometimes the simplest solutions are the best and your solution for the ports is spot on.....BigGrin BigGrin .. Well done...Cool Cool
7 Pages <1234>»
This page was generated in 0.763 seconds.
