Cutting ports ? Options
#1 Posted : 22 June 2013 17:44:53
Hi All,BigGrin
Just about to give the hull the big sanding session Crying , but looking forward I have a question about cutting the ports.
When I have taken extra care in marking out all the ports, do I cut them with the upper and lower faces parallel to the base or level to the appropriate face they are going through?
A simple diagram is added below, hope this helps to define what I am trying to get across Confused .
#2 Posted : 22 June 2013 18:04:10
top arrow.
#3 Posted : 22 June 2013 18:12:02
karl1113 wrote:
top arrow.
Hi Karl,BigGrin
Thanks for confirming my thoughts. Wanted to ask, because, when you use a marker jig it will sit flat to the outer surface of the hull and needed to know which way to angle the cut (albeit a very small angle to the outer surface of the hull)for accuracy.
Many Thanks. Cool
This page was generated in 0.188 seconds.
