Manifold pipes Options
stut2
#1 Posted : 23 June 2013 20:22:07
Hi guys, a quick question the v shaped marks on the manifold pipes (Circled red)
Am I correct that these are the burrs to be removed Confused Blushing
Thanks in advance
Simon the confused dot com
#2 Posted : 23 June 2013 21:36:56
Hi Simon, I wasn't sure at first but after examining photos of the real engine I removed them.
Look at the links in the reference guide
reference guide
you will see the pipes appear smooth.
Hope this helps (and that I got it right)
stut2
#3 Posted : 23 June 2013 22:00:00
reference guide
Thanks Graeme, much appreciated I have had a closer look at the PDF instructions and the reference guide and as you say pipes appear smooth, I didn't want to remove without first getting a second opinion.
thanks once again.
Simon the not so confused dot com
#4 Posted : 23 June 2013 22:33:53
BigGrin Hi Simon
If you look at the official build parts 1-8 post #5 12th picture you can see that the marks you are asking about have been removed
stut2
#5 Posted : 23 June 2013 22:56:32
BigGrin Hi Simon
Thanks Andy you are correct not sure how I missed that oneBlushing
Cheers
Simon
This page was generated in 0.354 seconds.
