trimming top edge Options
stujue
#1 Posted : 25 June 2013 11:00:20
Ive trimmed the top edge to the figures quoted in the magazine however as you can see from the picture frames 20, 21, 22 are all sitting below the cut edge by about 2-3mm, the directions say that the cut edge should end up level with the top of the frames. Can anyone tell me if this ail be a problem, or do i need to trim the top edge down more. Im not sure whats coming up in the area so no idea if this will be a problem.
Cheers Stu
Cheers Stu
Admiral Anti Spiral
#2 Posted : 25 June 2013 12:09:29
i had a similar out come, its not too much of a problem, if the time comes just cut it down, otherwise probably best to leave it, it may be accounting for the deck and planking to come.
Processing - Progressing
Previous builds: HMS Victory
stujue
#3 Posted : 25 June 2013 16:34:20
Thanks Admiral. good advice
stu BigGrin BigGrin
Cheers Stu
This page was generated in 1.273 seconds.
