12 Pages <1234>»
Kobus' SOTS Build - SA Options
KobusBeukes
#21 Posted : 27 June 2013 20:46:43
Started on the launch today.LOL
When unpacking I realised how small it is!Huh . Better be working very carefully!Blink
Kobus
Current Build
#22 Posted : 27 June 2013 22:40:46
Hi Kobus, the launch is small and be especially careful with those ribs, they are very delicate.... Cool Cool .. She really is fun to build though....Cool Cool
KobusBeukes
#23 Posted : 07 July 2013 18:27:41
Finished with the four issues, 8 - 11, I received. Completed the launch and cut it loose from it's support block.
Now have to wait for the next delivery before I can continue!Angry
Happy building to all!
Kobus
Current Build
KobusBeukes
#24 Posted : 07 July 2013 18:41:07
Finally got some wood that I can use for my build. LOL Although it is still 75 mm (3") wide it is only about 3 mm (1/8") thick and I can cut it into planks of 4 - 5 mm.
And I got myself a Dremel, as I cannot wait or rely on Jacklin, for the 'free' gifts they promised.Cursing Still haven't recieved any of the advertised gifts.
Kobus
Current Build
NMBROOK
#25 Posted : 07 July 2013 21:37:16
Nice work KobusBigGrin .Whilst the free drill is good for the smaller jobs,you will find the dremel has plenty of umpf for continuous work.I have had mine 14yrs,and as you Know from my build,it hasn't had an easy life.Nice find with the timber,cherry especially as this looks beautiful when used on a model.
Kind Regards Nigel
#26 Posted : 07 July 2013 22:34:40
Steady progress Kobus, looking good.... Cool Cool
KobusBeukes
#27 Posted : 08 July 2013 05:55:06
Kind Regards Nigel
Hi Nigel
Thanks for the feedback, much appreciated.BigGrin
Kobus
Current Build
KobusBeukes
#28 Posted : 08 July 2013 05:56:31
Hi Alan
Thanks for the fhe feedback.BigGrin
Kobus
Current Build
#29 Posted : 08 July 2013 12:27:07
Hi Kobus,BigGrin BigGrin
That`s coming on nicely and as for the Dremel it`s a great tool. I have purchased the same one but with the extra accessories, just in case they were needed later on.
If you intend to use the supplied bamboo for your first planking, then
you will get a lot of use with it. Having marked out my cannon and entry ports, I used a small round end reamer to remove most of the bamboo from the ports, but be careful as it has a tendency to try and skip across the surface. The big advantage though is the amount of time it saves.
Keep up the good work.Cool Cool
KobusBeukes
#30 Posted : 08 July 2013 15:10:39
Hi Derek
Thanks for the info, much appreciated.
I'm definately going to plank with the bamboo for the first planking.
I've seen that there is a Spiral Cutting Bit available, ever used that before?
Kobus
Current Build
NMBROOK
#31 Posted : 08 July 2013 15:44:19
Hi Derek
Hi Kobus
I know the one you mean,but it is designed for cutting ceramic tiles.I bought one for doing that job,for which it is brilliant,but tried it on wood and it is a little to fine and tends to burn the wood.You may find a spiral cutter that is intended for use with the rotazip cutter.I stick to the normal wood milling cutters.
Kind Regards Nigel
#32 Posted : 08 July 2013 16:48:38
Hi Kobus,BigGrin
I concur with Nigel and say "keep to the tooling bits meant for wood", then with a little bit of care as mentioned before you will get the results you want.
Good Luck.
KobusBeukes
#33 Posted : 08 July 2013 20:39:47
Hi Nigel and Derek
Thanks for the heads up, as I was contemplating in buying one.
I can recommend this forum to any new builder as help and advice are always available!BigGrin
Kobus
Current Build
#34 Posted : 08 July 2013 22:05:19
Hi Kobus, think you will find the dremel will become your trusted friend but would suggest you practice a little with the various attachments before using it on your build..... Just for info, this is the bit I used with the dremel to cut out the gun ports on the bamboo.. Just make sure you keep a good hold of it as it has a tendency to want to skip across your work.....Cool Cool .. Hope it helps..
KobusBeukes
#35 Posted : 09 July 2013 05:58:17
Hi Alan
Thanks for the info.BigGrin Will definately practice with the Dremel before I take it to the build.BigGrin
Kobus
Current Build
#36 Posted : 09 July 2013 08:38:01
BigGrin Hi Kobus I made a piece of hull out of spare bamboo to practice on BigGrin Rgd Martyn
Martyn Ingram attached the following image(s):
KobusBeukes
#37 Posted : 09 July 2013 14:21:48
Hi Martyn
Thanks for the tip, will definately follow this route before I start cutting any holes in the build. BigGrin
Kobus
Current Build
stujue
#38 Posted : 09 July 2013 18:05:34
hi Kobus
I had the same idea as martin, but dont throw it away. i used mine to try out the second plank caulking and also cutting the sapele needs a try before going into the main ship. keep the photos coming.
BigGrin BigGrin
Cheers Stu
KobusBeukes
#39 Posted : 09 July 2013 20:59:44
Hi Stu
Thanks for the info! Will definately do some practice as I'm waiting for my next deliveries Crying !
Kobus
Current Build
KobusBeukes
#40 Posted : 19 July 2013 21:00:29
Received the next four issues, i.e. 12, 13, 14 and 15, today!LOL LOL LOL
Will post some pictures over the weekend!BigGrin
Enjoy your builds!
Kobus
Current Build
12 Pages <1234>»
This page was generated in 0.527 seconds.
