Hull planking - top edge marking Options
#1 Posted : 02 July 2013 19:38:39
Hi All, BigGrin
I have just marked out the top edge of my hull planking and have a question.
Does the top edge between Rib#7 and Rib#16 have a slight curve to it, while all the other top edges are a straight line?
Captain David
#2 Posted : 02 July 2013 20:38:21
I started with the first plank following the curve of the second deck.
All of my subsequent planks are following that curve, all down the sides.
Did I do this wrong?
#3 Posted : 02 July 2013 20:42:38
Hi Cap`n, BigGrin
No you done nothing wrong, I am questioning where we cut the top level of the planking.
stujue
#4 Posted : 02 July 2013 20:48:34
Hi Derek
I found that the upper level at the fwd end has a slight curve downwards from fwd to aft. then the lower level at mid ships (the bit you are talking about) has got a curve, dipping in the middle, this should follow the same curve as the gun ports. I found the next rise also has a curve similar to the midships, then the last two rises seamed to be straight. If your worried you could always leave a bit on to take off later.
Hope this helps. BigGrin BigGrin
Cheers Stu
#5 Posted : 02 July 2013 21:00:56
stujue wrote:
Hi Derek
Cheers Stu,BigGrin
That about bears out what I`ve got.
The fore section curve is so slight it`s hardly noticeable, the stern sections are straight, but the midships section has a curve.
Many thanks for looking in and giving your advise.Cool
This page was generated in 1.179 seconds.
