162 Pages «<6364656667>»
#1281 Posted : 06 July 2013 23:08:45
NMBROOK wrote:
She's coming on well and looking good AlanBigGrin BigGrin
Kind Regards Nigel
Thanks Nigel, appreciate your comments... Cool Cool
#1282 Posted : 06 July 2013 23:16:57
BigGrin Hi Alan
If I were you I would be well chuffedDrool on how she is looking, congratulations on your build so far
#1283 Posted : 06 July 2013 23:28:25
BigGrin Hi Alan
Thanks for the very kind comments Andy and yes, I am very chuffed with how she has turned out so far and proud of the achievement.... Am also very much aware there is a heck of a long way to go yet though and looking forward to it all....Cool Cool
#1284 Posted : 07 July 2013 22:38:54
Well today continued work as per issue 37, finished trimming up the second planking on the starboard side, cut the gun ports and finished treenailing... Also finished marking out the port side and completed the upper planking.... Cool Cool .. Tomorrow hope to finish treenailing the port side, trim up, cut the gun ports out and then give it a sanding... that will be the end of issue 37....BigGrin BigGrin
NMBROOK
#1285 Posted : 07 July 2013 22:54:41
She's coming on well AlanBigGrin BigGrin lovely work.I bet you are looking forward to a treenailing reprieve for a while(ish)
Kind Regards Nigel
#1286 Posted : 07 July 2013 23:08:35
Kind Regards Nigel
Thanks for the kind words Nigel, appreciated. Cool Cool .. Can finally see light at the end of the tunnel with treenailing, only have the port side to do plus the few sapele planks on the stern.... BigGrin BigGrin .. Getting very close to masking off and painting the black top and red strip.... now that will be something different for a change....BigGrin BigGrin
#1287 Posted : 10 July 2013 00:14:22
Have sort of come to a standstill right now...Cursing Cursing ..Issue 38 is complete and started working on issue 39. Decided to look at the fitting of the keel so started off by trimming and dry fitting the stern piece and suddenly noticed I had made an all mighty foh pah!!!Cursing Cursing Cursing .. Noticed I had tapered off the planks to the stern piece on one side only and have second planked over the top....Cursing Cursing .. Have now had to carefully separate the second planking from the bamboo where the stern piece is fitted, doing this with a very sharp blade and a lot of care and patience..... After separation have now started to trim the bamboo to a nice taper, taken a good couple of hours so far.....Mad Mad thankfully with no damage....Cool Cool .. Hopefully will finish it off tomorrow evening..... pics to follow then....Cool Cool . The keel will be planked with walnut sheet and strips....Cool Cool
#1288 Posted : 10 July 2013 00:49:40
Decided after reading my previous post I would post a couple of pics to show the problem area and how I am tackling it... Cool Cool .. Notice my favourite tool.... the good old trusty cocktail stick.....LOL LOL
NMBROOK
#1289 Posted : 10 July 2013 02:06:20
Gosh Alan,that is a very gutsy way of tackling it.I would probably have chased a slot out of the keel with the dremel and fitted a narrower wood insert covered in epoxy then nipped it up with clamps.I hope you manage to sort it,like you say no problems only solutions.
Kind Regards Nigel
KobusBeukes
#1290 Posted : 10 July 2013 06:04:49
Hi Alan
Sorry to hear of the problem, oh what problem? Confused
Well done on the fix, looking good!BigGrin
Kobus
Current Build
#1291 Posted : 10 July 2013 08:03:41
BigGrin Well done on the fix Alan stunning job ThumpUp Rgd Martyn
claret
#1292 Posted : 10 July 2013 08:08:36
Hi Alan,
So much to do, it is easily done!Cursing
Glad you have rectified it without to much additional work.
'Cocktail sticks Rule!!!'
Sausage and cheese sticks at parties will never be the sameLOL LOL
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1293 Posted : 10 July 2013 09:26:46
Hi Alan,BigGrin
WTG, great fix.
It`s now official, a Cocktail stick is now THE modelling tool must have!
LOL Flapper LOL Flapper LOL Flapper LOL
#1294 Posted : 10 July 2013 12:03:10
Well done good job on the "fix". All hail to the cocktail stickLOL LOL LOL LOL
stujue
#1295 Posted : 10 July 2013 20:57:38
well executed solution Alan, All hail the trusty cocktail stickLOL LOL LOL LOL
Cheers Stu
#1296 Posted : 10 July 2013 23:19:05
Kind Regards Nigel
Thanks Nigel and I had thought about your solution but thought it would still look unbalanced by being too thick on one side.... Perhaps it was a gutsy way of tackling it but thankfully it appears to have worked out nicely as you will see by the posts below....Cool Cool ..Another solution found...Cool .. Think when I finally frame this build I will also enclose a polished cocktail stick as a momento.....LOL LOL LOL
#1297 Posted : 10 July 2013 23:21:41
KobusBeukes wrote:
Hi Alan
Thanks for the encouragement Kobus, appreciate it.... The fix still has a ways to go yet though....Cool Cool
#1298 Posted : 10 July 2013 23:24:36
Thanks Martyn, more to come....BigGrin BigGrin
#1299 Posted : 10 July 2013 23:26:01
claret wrote:
Hi Alan,
Claret
Thanks Claret, simply a lack of attention caused this, a little bit careless of me.... work ongoing on the fix and boy, do I love cocktail sticks......LOL LOL
#1300 Posted : 10 July 2013 23:27:16
delboy271155 wrote:
Hi Alan,BigGrin
WTG, great fix.
Thanks Derek and I sincerely hope it will end up being a great fix but have to say I did have my heart in my mouth for a while....LOL LOL
Guest (19)
This page was generated in 0.609 seconds.
