162 Pages «<6465666768>»
#1301 Posted : 10 July 2013 23:28:25
Hans wrote:
Well done good job on the "fix". All hail to the cocktail stickLOL LOL LOL LOL
Thanks Hans, always nice to get your comments.... Shame I had to do a fix in the first place, careless of me.....Cool
#1302 Posted : 10 July 2013 23:29:26
stujue wrote:
well executed solution Alan, All hail the trusty cocktail stickLOL LOL LOL LOL
Thanks Stujue, appreciate your positive comments.... BigGrin BigGrin
#1303 Posted : 10 July 2013 23:38:00
Hi Alan.
Very best of luck with your 'repair' on the stern, It looks like its going really well so far.
It's strange how we can concentrate so hard on all the tiddly little details that we need a magnifying glass to see and yet something as major as forgetting to chamfer the stern on both sides or not realising that half my skid beams were missing goes right by us without a second glance!BigGrin
Well done on your recovery though. (I've still got half of that cocktail stick from the bowsprit left if you need it! Flapper )
Keep them coming!
#1304 Posted : 10 July 2013 23:39:00
Tonight I continued with the stern fix and just to make sure everything would work out nicely I started working on the stern post itself...Cool Cool .. Continued to remove material from between the bamboo and the walnut, did this very gingerly...BigGrin BigGrin Once happy I glued the walnut planking back in place, clamped and left to cure....Cool Cool
#1305 Posted : 10 July 2013 23:43:41
With the stern post, first thing I did was to remove all the black ash from the edges...BigGrin .. Cut two pieces from 1mm walnut sheet to the thickness of the stern post, this will be for the stern post sides... Then cut a length of .6mm thick walnut to be used on the rear of the post... Glued and clamped the pieces in place leaving a 1.5mm inset along the post length...Cool Cool ..
#1306 Posted : 10 July 2013 23:55:21
Trimmed down and sanded the walnut on the stern post and finished off by dry fitting the whole thing to the hull..... Have to say I am over the moon by the way it all turned out...BigGrin BigGrin .. Will glue the stern post is place once I have prepped the keel and bow sections....BigGrin BigGrin
#1307 Posted : 10 July 2013 23:58:32
Finally this evening I masked the hull in preparation of painting the upper part of the hull black.....Cool Cool
Happy building all..
NMBROOK
#1308 Posted : 11 July 2013 00:01:18
Fantastic work AlanCool Cool I am glad you got it sorted.
Kind Regards Nigel
#1309 Posted : 11 July 2013 00:04:28
Kind Regards Nigel
Thanks again Nigel, at least now I can move on with the build... BigGrin BigGrin
#1310 Posted : 11 July 2013 00:51:42
Plymouth57 wrote:
Hi Alan.
Keep them coming!
Thanks Robin and am delighted with the way it has all turned out....Cool Cool .. And you are right of course, just goes to show no matter how much you concentrate and think you have everything covered, something crops up to bite you in the backside....LOL LOL .. Still, I always believe there are never problems, only solutions.... selecting the right solution is the hard part.... BigGrin BigGrin .. You keep that cocktail stick, it's an invaluable tool to have....Flapper Flapper Flapper
KobusBeukes
#1311 Posted : 11 July 2013 05:57:25
Hi Alan
Knew you would get the perfect solution!BigGrin
Well done and keep the pics coming!LOL
Kobus
Current Build
Admiral Anti Spiral
#1312 Posted : 11 July 2013 13:31:26
brilliant work alan, great work on the stern BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1313 Posted : 11 July 2013 21:44:05
KobusBeukes wrote:
Hi Alan
Thanks Kobus, not sure about being perfect but know I am exceptionally happy with the results....BigGrin BigGrin .. Thanks for looking in and commenting....Cool Cool
#1314 Posted : 11 July 2013 21:45:13
Thanks for the very nice comments Admiral and your continued interest..... Cool Cool
#1315 Posted : 11 July 2013 22:01:30
Tonight another milestone was achieved this evening, it is the first time I have ever used an airbrush and am so very pleased with the results....Cool Cool .. Also pleased I took time out and had a few practice sessions just to get the feel of how it all worked...including the mixing and thinning of the paint.BigGrin BigGrin.. Completed painting the upper hull black so tomorrow I may have a go at painting the red strip..... Very pleased with how it looks.....Cool Cool
NMBROOK
#1316 Posted : 11 July 2013 22:15:55
Excellent work AlanCool Cool She's looking really good.
Kind Regards Nigel
#1317 Posted : 11 July 2013 22:19:01
Kind Regards Nigel
Thanks Nigel, one of the nice things that isn't showing up on the pics is you can still see the treenailing even though I have painted over the top... The treenails have the appearance of being slightly raised....Cool Cool
der Gohfelder
#1318 Posted : 11 July 2013 22:24:10
Hi Alan!
A very nice work, well done ! ThumpUp ThumpUp ThumpUp
Best regards, Bernd
stujue
#1319 Posted : 11 July 2013 22:49:12
cool job Alan.BigGrin BigGrin coming on a treat.
Any advice on the airbrushing like ratio of paint to water mixes. BigGrin BigGrin
Cheers Stu
#1320 Posted : 11 July 2013 23:12:26
der Gohfelder wrote:
Hi Alan!
Best regards, Bernd
Thanks very much Bernd, appreciated....Cool Cool
This page was generated in 1.900 seconds.
