Joined: 12/02/2010 Posts: 44 Points: 108 Location: Oakdale, Blackwood, Gwent
In issue 42, step 1, it says to use bamboo strips that came with issue 40, but they were used up doing the gunwales, also at step 13 it says to use the same strips from issue 40 to plank around parts 68 and 69. Should we be using the strips of wood that came with issue 38, as I cant find any mention of where we are meant to use them. Andre Building:
DeAgostini:
HMS Victory HMS Surprise Sovereign of the Seas H.M.S Victory Cross-Section
Don't use the strips from 38 as they are basswood 1x3mm strips rather than bamboo 2x5mm strips.
You should have some 2x5mm bamboo strips left over from the hull planking and can use these.
Thanks Mr T Building:
DeAgostini:
Joined: 03/10/2012 Posts: 20 Points: 60 Location: Wales
Tomick wrote:Don't use the strips from 38 as they are basswood 1x3mm strips rather than bamboo 2x5mm strips.
You should have some 2x5mm bamboo strips left over from the hull planking and can use these. I'm currently about to commence the gun port linings Mr T. The instructions tell me to use the basswood strips from Issue 39 but they seem too large, should it read the basswood strips from issue 38 as they appear to be a better gauge for the job.
Quote:I'm currently about to commence the gun port linings Mr T. The instructions tell me to use the basswood strips from Issue 39 but they seem too large, should it read the basswood strips from issue 38 as they appear to be a better gauge for the job. No, that's correct Mike. Use the 1.5 x 5mm Birchwood Strips from Issue 39. They do look big and are quite fiddly as they protrude backwards into the Hull with only a thin support at the front. I've just finished mine, so enjoy
Didn't realise you had changed your name Andy
Tomick wrote:Didn't realise you had changed your name Andy Sorry, seem to be putting my foot in it everywhere tonight, think I'll go and have a lie down
You'll be after a job on the team next
 Pick me Pick me Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
