25 Pages «<1213141516>»
Claret's SOTS Build Diary Options
claret
#261 Posted : 11 July 2013 09:31:45
Hi,
Just a couple of photos for all the cocktail stick fansLOL LOL
Almost finished top side treenailing.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Admiral Anti Spiral
#262 Posted : 11 July 2013 13:32:46
lovely work claretBigGrin the treenailing will be a great added detailBigGrin
Processing - Progressing
Previous builds: HMS Victory
#263 Posted : 11 July 2013 21:32:26
I miss those sticks, they should be part of my collection......LOL LOL .. Lovely work Claret, very well done.....BigGrin BigGrin
stujue
#264 Posted : 11 July 2013 22:37:36
Hi Claret. looking really good mate.Cool Cool
What are you using as glue for your cocktail sticks and how are you cutting them down. ive had a little play and when i snip mine off some fall out. Cursing
BigGrin BigGrin
Cheers Stu
claret
#265 Posted : 13 July 2013 00:24:09
Hi Alan,
Many thanks for the comments, but they are all mine!LOL I have found a cocktail stick mine here in east lancs.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#266 Posted : 13 July 2013 00:25:12
Thanks admiral.
I am pleased how they have turned out.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#267 Posted : 13 July 2013 00:30:17
Hi Stu,
Sorry for not replying earlier, have been in mid Wales for my sons graduation.
The glue is the aliphatic type supplied by CMB. Alan (Gandale) has a photo in one of his posts.
I drill a 0.5mm hole and cut the cocktail stick in half before dipping the end in glue and inserting into the drilled hole.
Generally the stick is sharply tapered, but if not I have gently whittled the end to a point with a sharp scalpel.
Hope this helps.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
stujue
#268 Posted : 13 July 2013 15:28:11
claret wrote:
Hi Stu,
Hope this helps.
Claret
thanks claret. and my congratulations to your son. BigGrin BigGrin BigGrin
Cheers Stu
claret
#269 Posted : 13 July 2013 16:56:46
Thanks Stu.
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#270 Posted : 18 July 2013 21:45:47
Hi,
Just having a break from planking and tree nailing.
I glued the assembly together, let the glue cure, but as I am using 1mm grating, i had to put an additional cross member in to ensure all the holes were less than 33x33mm to fit the new grating.
i scored and pencilled the cross members to look like plank assemblies but struggled for treenails. I remebered I had some hornby track pins, they are very thin and worked a treat.
The photo shows the pins glued in place before cutting down.
More to follow soon. thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#271 Posted : 18 July 2013 22:20:37
Really like what you have done there Claret, very well done.....BigGrin BigGrin
claret
#272 Posted : 18 July 2013 22:57:12
Thanks Alan,
Always appreciate your comments and looking.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#273 Posted : 19 July 2013 00:22:07
Nice out of the box thinking there ClaretCool Cool
Kind Regards Nigel
claret
#274 Posted : 19 July 2013 08:07:23
Thanks Nigel,
It is not very often I am allowed out of the box, especially unsupervised!LOL
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Admiral Anti Spiral
#275 Posted : 19 July 2013 23:07:19
nice work claret BigGrin i was thinking of getting some of those pins a while back
claret
#276 Posted : 22 July 2013 11:08:53
Hi Admiral,
Thanks. They are only blackened on the surface, so bright metal once cut off, but still looks okay.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#277 Posted : 24 July 2013 19:30:52
Hi,
Finished the first stage of the secondary planking, so glued the gallery supports ready to take the transom.
Whilst waiting for the glue to cure with the transom clamped in place, I did some more work on the bow beak.
I stained the wood with dark oak, giving it three coats. I also lined all the holes with basswood before starting to fit the 1mm grating I purchased from CMB's.
My progress so far is shown in the pics below.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#278 Posted : 24 July 2013 21:41:10
Lovely work ClaretCool Cool I like the basswood lined holes,the cut gratings will look so much better for itCool Oh and are you aware of a strange beardlike growth on the stern?LOL LOL LOL
Kind Regards Nigel
#279 Posted : 24 July 2013 22:34:35
Lovely work there Claret and I have to agree with Nigel, very nice idea lining the holes for the gratings, will give a much better finish.... Cool Cool ..
claret
#280 Posted : 25 July 2013 00:36:34
Hi Nigel & Alan,
Thanks for your comments and looking in.
The bearded growth is only a touch of cocktail stickitas!BigGrin Nothing a little snipping and sanding can not cureLOL
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
This page was generated in 0.567 seconds.
