Hi All, Do we, anywhere in the run of things know if the entry ports will be in the open or closed position? Reason for asking is, if, they will be open then the dummy gun supports will be visible and I would prefer to remove that section and show internal decking albeit a small amount. I am decking that section just in case any lower deck is visible through the hatches, so would rather deck all the area in one go while I`m at it. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
it'll probably be closed but then again what would be the reason for the big hole if it was to be closed, a good question, but its probably better to close it because other than a planked deck theres no much to see Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
I am guessing they may be open, because the dummy gun support beams have been deliberately extended past them.
You might be able to identify for sure via the Italian site.
Hi Del The Italian site hasn't got that far yet.I would have edged my bets that the entrance port is closed and is a complete casting,surround with door.Hence the hole to clear the back of the door as it is recessed.There is nothing in the Italian build to suggest any different as no internal detail has been fitted. Kind Regards Nigel
Thanks Guys, Have checked the Italian site and can confirm as stated "they ain`t got that far" and agree that it will most likely be closed, because on further thought I`m thinking, that if the gun ports are open with the cannon pointing out to sea, then it`s unlikely they will have an open door policy.  . Thanks for looking in and your thoughts, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Del Have a look here, it might be of help http://www.model-space.c...ign-of-the-seas/details
regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
WTG Andy, Well spotted, just goes to show you can look at something and still not see (won`t tell you how many times I must have missed that one  ) Thanks, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
