dont glue the ribs yet?? Options
benny
#1 Posted : 10 June 2010 21:30:17
hi all..maybe i have missed something..but why is it not wise to glue the ribs yet surely if you set your jig correctly and as you slot the ribs into the keel they fit and are square and clamped then wheres the problem...been bothering me for a while...thanks paul
cheers benny
John Wreford
#2 Posted : 10 June 2010 21:37:52
I would guess that there will be lower deck that is fitted at the same time. Would probably help to keep everything true?
Any experienced builders like to comment?
John
benny
#3 Posted : 10 June 2010 21:42:16
thanks john but if thats the case why do they show in the mags to glue as you go...i have seen a few post saying not to glue but nobody says why
cheers benny
amipal
#4 Posted : 11 June 2010 00:21:36
Don't they say not to glue in the magazine?
drh63
#5 Posted : 11 June 2010 01:06:53
Rank: Beginner Level 3
You should not be gluing any of the frames in place except the very first one. The reason for this is that its important to make sure that everything lines uo and is straight and true otherwise you end up with a twisted frame.
To prevent this happening, one of the ships decks will be used to help keep everything rigid. You will need to be able to align the frames with that deck so that the deck sits flat and true. The deck will help you to correctly align the frames. If your frames are not all properly aligned and you have glued them to the keel, your deck will not be flat.
Everything will be out of shape.
So wait until you are instructed to glue them to the keel, by which time you should have the relevant deck sections.
Dave.
Current Build: Le'Astrolabe.
benny
#6 Posted : 11 June 2010 08:04:11
good answer thanks dave
cheers benny
benny
#7 Posted : 11 June 2010 08:07:52
your right too amipal thanks
cheers benny
#8 Posted : 11 June 2010 09:19:41
Ditto that Dave, the lower gun decks are used to align each frame exactly, certainly each mag so far has advised not to glue any frames into the the keel other than those at the bow.
#9 Posted : 11 June 2010 11:22:38
Started putting Victory together yesterday after receiving issue 10 and the stern end of the keel frame, and as the instructions clearly state that the ribs should not be glued yet, it does not state why, but looking closely at the accompanying DVD and the installation of the lower deck clearly plays a big part with alignment...it was the same with the Del Prado Bounty build where I almost fluffed up due to the same reason...Blushing
chrisN257752
#10 Posted : 11 June 2010 14:50:30
Rank: Beginner Level 1
pls advise how do you get the flat and straightBigGrin
Son of Bulwark
#11 Posted : 11 June 2010 15:12:26
Hi shipmates!BigGrin
The ribs shouldn't be glued yet, as by the time you get the lower deck part the glue will have set fully and there will be no give. Assembling the bow is ok! as is putting the internal keel together is ok! even glueing the ribs together is ok!, but don't glue the ribs to the keel until you have all the ribs & lower deck.
Then when you have a full day to yourself start to glue the ribs into place keeping them at right-angles clamping them in place for 30 minutes before moving to the next. When all the ribs are fitted place the lower deck in place to hold the ship square, the glue should have enough give to fit the deck with ease.
Please only use PVA glue not the fast set type of PVA and no super glue,Unsure REMEMBER NO SUPER GLUE!
I'm still working on the final design for the jig as I want a jig that can be used as a building slip, a planking support and used as a ropewalk. I just want it all a multifunctional jig, the first attachment for keeping the ribs square as the glue sets is almost finished. The attachments and keel support brackets will fit into two routed channels, I also have two wooden clamps (tapestry clamps) which can be screwed to the base for planking.
The ropewalk attachment has been held up as I'm waiting of the last gear to be sent as the supplier ran out of stock. Mad
Good Luck! shipmates! ThumpUp
Zeptrader
#12 Posted : 11 June 2010 15:20:00
Care to share any pictures of your ropewalk and the jig of course BigGrin
CaptnBirdseye
#13 Posted : 11 June 2010 17:09:05
Rank: Superelite
I second that BigGrin Can see another production line here!!!
Son of Bulwark
#14 Posted : 11 June 2010 17:29:58
Hi Zeptrader & CaptBirdseye! BigGrin
When I get it finished I will Post the Pictures and details of the design, may take a while as I have just started to do my Dad's kitchen the old seadog can't do it at his age! it's just not safe for the old man!. Laugh
The jig will be done in the next 2 or 3 weeks.ThumpUp
#15 Posted : 11 June 2010 21:17:03
Very important guys.......
Don't do any shaping to the keel along its full length (including at the bow)!
The way the model is planked leaves the width of the keel exposed along its entire length, so that later on an external keel can be added to what should be a flat contact edge of the already installed keel, obviously when the time comes the hull frames will be chamfered to suit the lie of planking along the hull.
benny
#16 Posted : 12 June 2010 13:21:33
thanks for all your replies..i can be a prat sometimes Blushing ..jumping in without reading things properly.theres a lesson learnt. just glad i havnt started gluing..
cheers benny
#17 Posted : 12 June 2010 15:21:06
I second you on that advice Tomick, began my build yesterday, and the only thing glued are the bow formers. All the shaping will come much later when all the frames are eventually glued in place, which adds to its rigidity when it comes to forming the hull's over all shape, and of course make way for the real keel...ThumpUp
luna
#18 Posted : 12 June 2010 16:47:22
Hi Just wondering when we eventually get the lower deck would it no be easier to do (as i have seen in other builds) a 70/30 pva mix and paint it on to the frames/keel after we have fitted the deck? this would ensure there will be no problems with fit etc.
Glen
Glen
There are two types of Boats in the Royal Navy
Submarines and Targets.
This page was generated in 0.279 seconds.
