12 Pages <12345>»
Kobus' SOTS Build - SA Options
#41 Posted : 19 July 2013 22:38:02
KobusBeukes wrote:
Received the next four issues, i.e. 12, 13, 14 and 15, today!LOL LOL LOL
Will post some pictures over the weekend!BigGrin
Enjoy your builds!
Will look forward to seeing them Kobus....Cool Cool
KobusBeukes
#42 Posted : 20 July 2013 06:33:27
Hi Alan
Thanks for the engouragement!BigGrin
Kobus
Current Build
#43 Posted : 20 July 2013 10:09:25
Hi Kobus, your build is looking goodBigGrin the guys are giving you great advice and keeping you on the right trackBigGrin Good stuff kind regards Mike
KobusBeukes
#44 Posted : 20 July 2013 18:05:41
Hi Mike
I appreciate all the advice I get from the forum! BigGrin To follow the other builds is an eye opener and the modifications are stunning!
Kobus
Current Build
KobusBeukes
#45 Posted : 21 July 2013 20:38:47
I've done some work this past weekend.BigGrin
The dummy gun supports were cut and glued as well as the supports beams for the second deck!LOL
Decided to follow others and used 5 mm dowel stick to support the support beams. The support beams are much stronger with the dowel sticks in place!
I'm considering to follow Alan (Gandale) with the prow. Alan cladded the prow with walnut and it looks marvelous!Drool
Althought mine is already glued I want to steam it loose and then cut the prow out of 1/8" (3.15 mm) solid wallnut. I know it is thinner than the 4 mm plywood but don't think it will make such a difference.
Enjoy the buildingBigGrin
Kobus
Current Build
NMBROOK
#46 Posted : 21 July 2013 20:41:28
Nice clean accurate work KobusCool Cool Now you are up and runningBigGrin
Kind Regards Nigel
KobusBeukes
#47 Posted : 21 July 2013 20:46:40
Kind Regards Nigel
Hi Nigel
Thanks for the encouragement and looking in.BigGrin
Kobus
Current Build
#48 Posted : 21 July 2013 23:22:24
Beautiful work Kobus and very well done indeed...BigGrin BigGrin .. Very soon you will be planking the lady and I look forward to seeing it....Cool Cool
KobusBeukes
#49 Posted : 22 July 2013 06:23:16
Hi Alan
Thanks for looking in and the word of engouragement!BigGrin Much appreciated!
Kobus
Current Build
#50 Posted : 22 July 2013 10:34:11
Good work there Kobus, nice clean build, keep it up.
claret
#51 Posted : 22 July 2013 11:14:40
Hi Kobus,
Looking forward to seeing your progress.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#52 Posted : 22 July 2013 19:20:36
Hi Kobus,BigGrin
Your progress is looking good WTG.
KobusBeukes
#53 Posted : 22 July 2013 20:06:28
Hi Hans, Claret and Derek
Thanks for looking in and the encouragement. It is apreciated!BigGrin
Kobus
Current Build
KobusBeukes
#54 Posted : 27 July 2013 14:35:35
Just a small update. Installed the second deck and sprayed the outer surfaces of the stringers and decks black.
Kobus
Current Build
NMBROOK
#55 Posted : 27 July 2013 14:53:42
Nice work KobusCool you are progressing well and will soon be plankingBigGrin
Kind Regards Nigel
KobusBeukes
#56 Posted : 27 July 2013 16:31:47
Kind Regards Nigel
Hi Nigel
Thanks for the nice feedback. Much appreciated!BigGrin BigGrin BigGrin
Kobus
Current Build
KobusBeukes
#57 Posted : 27 July 2013 16:36:58
Another update for the day.
Painted the launch with a wood primer. Tested the Humbrol RC417, ivory white, but it seems green?Confused
The stick on the right is painted white.
Kobus
Current Build
#58 Posted : 27 July 2013 22:04:54
Hi Kobus, nicely done there and the launch is also looking good... I too used the same white and yes it looks as if it has a green tinge to it, once its on I rather liked it.....Cool Cool .. Keep em coming...BigGrin BigGrin
KobusBeukes
#59 Posted : 27 July 2013 22:19:14
Hi Alan
Thanks for the feedback, was quite suprise when I opened the tin and saw the color Confused !
Hopefully it will turn out good.BigGrin
Kobus
Current Build
#60 Posted : 27 July 2013 22:32:56
Hi Kobus
another colour to try is Barley White which has a brown off white tinge that sometimes looks better than the green tinge
12 Pages <12345>»
This page was generated in 0.181 seconds.
