162 Pages «<6869707172>»
KobusBeukes
#1381 Posted : 20 July 2013 06:39:49
Hi Alan
Nice work there on the prow! BigGrin Pitty mine is glued alreadyCrying !!!
It pays not to be in a hurry!
Well done!
Kobus
Current Build
#1382 Posted : 20 July 2013 07:20:07
BigGrin Stunning work Alan love it Love Rgd Martyn
#1383 Posted : 20 July 2013 11:52:35
KobusBeukes wrote:
Hi Alan
Well done!
Thanks Kobus, still some way to go yet before it's finished... hopefully sometime over the course of this weekend the prow and the keel will be completed... Cool Cool
#1384 Posted : 20 July 2013 11:53:36
Thanks Martyn for the lovely comments....Cool Cool
#1385 Posted : 20 July 2013 16:11:55
Hi Alan,BigGrin
Things are looking real good. I`ve not had a lot of time to keep up recently due to work and the second planking, which I thought was going to be a little troublesome but (thanks to some of your excellent close up pics)has not been half as bad as I thought.
Keep up the good work and don`t forget the close ups Cool Cool .
#1386 Posted : 20 July 2013 23:02:43
delboy271155 wrote:
Hi Alan,BigGrin
Thank you Derek, appreciated...Cool Cool .. If my diary and any of the close up pics help you in any way to achieve the build you desire then I am more than happy m8.... it is one of the reasons I decided to do a diary, to help others and for others to advise me when I am going wrong....BigGrin BigGrin ..Looking forward to seeing your progress... Cool Cool
#1387 Posted : 20 July 2013 23:05:28
Well tonight I finally managed to finish cladding the prow and ribs with walnut sheet...Cool Cool . Ribs were glued in place and when dry I finally attached the whole section to the hull....BigGrin BigGrin .. I really am happy with the way it has turned out and to be honest I don't think the pics do it justice, looks a lot better in the flesh... Cool Cool .. well worth the effort I put in... Tomorrow hopefully will be able to clad the remaining 3 pieces of the keel and get them fitted....BigGrin BigGrin
NMBROOK
#1388 Posted : 20 July 2013 23:20:19
Truely great work AlanCool Cool
I think you may find that because of the large sides of the beak in the kit design that they are enough black when painted and the walnut on your prow will help balance it out.
Kind Regards Nigel
#1389 Posted : 20 July 2013 23:32:17
Kind Regards Nigel
Thanks very much for the encouraging comments Nigel...Cool Cool .. Toying with actually just adding a dark stain to the top of the prow and beak heads rather than paint them black... To be honest, I would really like to continue with this build using a minimal amount of paint and try to achieve a natural wood finish with the use of some stains.... Cool Cool .. Just thinking ahead for now.... BigGrin BigGrin
NMBROOK
#1390 Posted : 20 July 2013 23:51:56
Kind Regards Nigel
I agree Alan,I think less is more regarding paint on a ship of this type and period.
Kind Regards Nigel
#1391 Posted : 21 July 2013 01:12:18
BigGrin Some very nice work there Alan, artists inks may be another way to go with staining your wood too.
#1392 Posted : 21 July 2013 11:15:16
Hi Andy, thanks for looking in...Cool Cool .. Have thought about the use of inks but I have some walnut stain so am going to try a few experiments on scrap walnut to see what the effect will be... if that doesn't work out then I'll have a look to see what can be done with inks... Cool Cool .. Thanks again for the tip, appreciated...BigGrin
stujue
#1393 Posted : 21 July 2013 13:48:46
hi alan
looking really good. keep the photos coming for those who are following.BigGrin BigGrin BigGrin
Cheers Stu
KobusBeukes
#1394 Posted : 21 July 2013 20:14:52
Hi Alan
It looks fantastic! BigGrin You got me thinking on the prow! As I said earlier that mine is already glued, but I'm considering to steam it loose and cut the prow from solid wallnut! I recently bought some 1/8" wallnut. I know it is a fraction thinner than the 4 mm plywood, but don't think it will make suche a difference!
Thanks for a great idea! Keep up the good work!BigGrin
Kobus
Current Build
#1395 Posted : 21 July 2013 20:20:11
BigGrin Brtl work Alan well done on the keel BigGrin Rgd Martyn
#1396 Posted : 21 July 2013 23:24:11
stujue wrote:
hi alan
Thanks for looking in and commenting Stu....Cool Cool .. I fully intend to post plenty more pics and if they are of any use to those following on behind then it makes it all the more worth while....BigGrin BigGrin ..Thanks again..
#1397 Posted : 21 July 2013 23:28:06
KobusBeukes wrote:
Hi Alan
Hi Kobus, thanks for the encouraging comments... Cool Cool .. Don't see any real reason why you can't use slightly thinner walnut, only thing is you would have to add strips of packing into the rib slots in order to ensure a snug fit or, you can also make new ribs out of the same walnut sheet.... just a thought....BigGrin BigGrin .. I have ended up going the other way where I have increased the overall thickness of the prow and ribs from 4mm to 6mm.... BigGrin BigGrin ..Thanks again...
#1398 Posted : 21 July 2013 23:29:31
Thanks again Martyn, keel almost finished but I think I need another evening work on it yet before moving on.... BigGrin BigGrin... Will post pics of the finished keel when done...Cool
NMBROOK
#1399 Posted : 21 July 2013 23:30:41
Message was deleted by User.
Admiral Anti Spiral
#1400 Posted : 22 July 2013 00:02:15
Very stunning alan, with the work you've done its setting to become a top quality ship buildBigGrin Love
Processing - Progressing
Previous builds: HMS Victory
Guest (8)
This page was generated in 0.448 seconds.
