5 Pages <1234>»
HMS Victory by Constructo Build Log Options
cuandv
#21 Posted : 01 August 2013 22:09:03
Hey there Robin,
Thank you for your encouraging words. Being my first model, it Hs been very challenging so I am really relying on the sanding to help some of the "messy" joins.
I did what you said re the smaller planks up to 3rd rib and it seems to have made a small difference and I think that it will make the gaps a little smaller. Although I will still have gaps there, I think that filling them with a little wood dust from the sanding mixed with PVC should in my favor.
I really appreciate your comments.
Cheers
Cuan
HMS SOTS
HMS Victory
HMS Surprise
#22 Posted : 01 August 2013 22:27:12
Hi Cuan, looks like a nice kit you have there and the build is coming on a treat...Cool Cool .. From what I can make out I think you will fine the sanding down will work out very nicely.... I too have used the sanding dust mixed with PVA to fill some small cracks and gaps, has worked out very well for me....Cool Cool .. Keep the build going and I will drop by from time to time... good luck with her....BigGrin BigGrin
cuandv
#23 Posted : 02 August 2013 11:08:32
Thanks Alan. I have extremely worried about the look of the hull due to the small gaps and the "steps" between planks (some sleepless nights :))
I got a mouse sander which I think will make the difference but I just don't want to sand too much.
I would appreciate your dropping in here every now and then to check the progress. I am building the SOTS at the same time so its a bit of each ship here and there.
Cheers
HMS SOTS
HMS Victory
HMS Surprise
#24 Posted : 02 August 2013 11:19:02
I used a mouse sander on my victory, no problems at all and saves a lot of time too. Dont worry about how messy the hull looks before sanding, once done the hull will be transformed into a thing of beauty :-)
cuandv
#25 Posted : 02 August 2013 11:22:35
I look forward to the outcome.
Just a question:
What is the process now with regards the sanding. Is it best to start with the mouse sander for the general rougher sanding and then go to a more finer grain paper?
Also, when is the best time to fill the gaps with the wood dust, in between sanding? or before any sanding?
Thanks for your help guys.
HMS SOTS
HMS Victory
HMS Surprise
#26 Posted : 02 August 2013 17:02:25
Hi
I think on my victory I filled all over before any sanding and then again for the smaller areas after the mouse sander was used, then went on to hand sanding with a finer grit.
I painted and coppered my hull so wasnt too concerned with any visible filler, as long as it was smooth.
Main thing is dont worry about it, you will be amazed at how good it looks when all sanded down.
#27 Posted : 02 August 2013 23:32:26
Hi Cuan, I too am a first time builder, building the SOTS at present and have received a mountain of tips from lots of experienced builders in this forum so take time if you can to read some of their diaries.... Cool Cool .. This is a tip I picked up from Nigel who's SOTS build is superb... Take some offcuts and make up a section of planking making sure you include some gaps in the planks roughly to the size of the gaps you want to fill on the build.... When dry, mask off the gaps in your test piece and use wood filler of as close to the colour of the planks as you can get and fill the gap, the masking will prevent contamination of the surrounding area. When dry remove the masking tape and sand it down... this will give you an idea how it will look on your actual build.... Hope this helps a little....Cool Cool
cuandv
#28 Posted : 05 August 2013 09:03:19
Thanks Alan.
I think that's an excellent idea.
Will do that. I was scared of wood filler, because it always shows up slightly differently when coated with sealer/varnish.
Form what I have seen, it comes up a bit darker than the surrounding wood (Sapele in this case) and I didn't want to mess it up.
Blink
HMS SOTS
HMS Victory
HMS Surprise
#29 Posted : 05 August 2013 13:14:57
PVA and sawdust works fine on small gaps. If your painting the hull then an easy method for larger gaps is to shim it with off-cut planks and sand smooth when you sand the rest of the hull. If you are leaving natural and have an obvous gap i think it is always better to try and remove and rework the plank.
I have not tried the wood filler idea it does sound interesting if you can make it not obvous?!
#30 Posted : 05 August 2013 21:16:29
Hi Cuan. All the above methods work. I also use the method that Jase uses and it works. Matching pieces for the big gaps and pva and sawdust for the smaller gaps. I varnished my hull and it is not easy to see the filled gaps. Try which method works for you.
cuandv
#31 Posted : 06 August 2013 09:17:54
Thanks I will try the wood dust option and fill the small gaps with that and glue. WIll get this all sanded and reworked a little and then take some pics and put them up...Thanks Guys.
HMS SOTS
HMS Victory
HMS Surprise
cuandv
#32 Posted : 08 August 2013 14:18:50
I have been extremely worried about the steps in the planks, but after the first rough sanding, they have gone.
Attached pics of the first sanding/filling with sawdust from the sand.
I have been using a mouse sander for most of the ship but the corners at the stern have proved difficult here, so its back to manual snading for this. Cursing
I want to try get most of the small dents out of the wood with this sand (used a 60/80 grit sandpaper).
Now its done to a 120/140 grit for a mid sanding and then finally onto a 200 grit paper.
Anyone have any ideas for this?
cuandv attached the following image(s):
HMS SOTS
HMS Victory
HMS Surprise
#33 Posted : 08 August 2013 18:22:55
Hi Cuan.
See! Now that's a hull to be proud of! Well done! Cool
(These double-planked hull boys don't know what planking is until they've done a Constructo big-thick-planked job!) LOL BigGrin Flapper
Well done again!
cuandv
#34 Posted : 08 August 2013 20:53:18
BigGrin
serious stuff!BigGrin
I am looking forward to this coming out nicely now.
Robin, I am looking at keeping the wood natural. I am not keen to paint the ship as per the real VICTORY, but rather just light and darker wood variants.
What do you suggest?
Cheers
HMS SOTS
HMS Victory
HMS Surprise
#35 Posted : 08 August 2013 22:11:42
Hi Cuan.
As you can see from my own build diary, (DelPrado 1/100 Victory) my own personal taste is that you can't beat a Victory in her 'proper' colours! I must admit though that Bernd's 'natural wood' Vic is an absolute masterpiece to look at and my own Constructo "Grimsby" 12 Gun 'Frigate' was made up in her natural wood too.
In her case I used a clear sanding sealer on the deck veneer and the hull and masts were varnished with an acryllic semi-matt or eggshell finish clear varnish. Having gone to all that trouble with the light wood strips for the gun deck sides it would really be a shame to paint over it afterwards.
I would go with the clear varnish with possibly a woodstain to give the hull below the waterline a different shade to the main hull and also perhaps on the cannon carriages and other deck fittings to pick them out from the mass of the hull colour too.
Hope this helps, but I think she's going to look beautiful whichever way you go if the rest is built to the same standard as the hull!
Best of Luck
#36 Posted : 08 August 2013 22:13:15
Hi Cuan.
Very nice work, planking has turned out really well, credit to you.... Cool Cool
Marcel
#37 Posted : 14 August 2013 17:22:05
Your work looks exelent. Well done for a first one.
A tip I picked up is to shamfer the inner sides of the planks a bit to get them a closer fit on the round walls of the build.
Tip on planking: When the planks are laid completely flat, the sides naturaly seal, but on a round suface gaps apears... (think of when breaking a block from a Choc bar). A slight shamfer (Bevelling) will sort out this. Practice on a piece of left over wood, using a drinking glass to get that tight round corners filled.
Always fit one plank at atime and wait till the glue has dried, before moving on. The wet glue expans leaving tiny gaps when dried.
Happy building
Marcel
Sovereign of the Seas
cuandv
#38 Posted : 15 August 2013 13:09:03
yeah i saw that...I think I am going to do that on the SOTS.
Mellow
HMS SOTS
HMS Victory
HMS Surprise
cuandv
#39 Posted : 19 August 2013 09:21:16
Still busy with the planking. There are a few fillings I still need to do, especially on the bow and stern areas, but its coming on.
I wanted to fit the Keel/false keel so I could fill the small gaps beneath them. This proved difficult because of the differences in planking compared to the standard fit of the parts. Had to do some pushing and shoving, squeezing and holding, but it seems to have come out alright Confused
At the back of the ship, I still need to do a lot of filling and corner sanding just to generally make everything look better. You will notice that there a few pieces still sticking out of the sides. I have just glued these in and now need to round off a little to make it look proper.
I have decided to keep the natural colours of the wood on this ship. Being my first build, I wasn't keen on painting the victory colours. I will probably do this on the HMS Surprise build. Problem with this is that the planking needs to be as perfect and gap-free as possible as these cannot be covered up by paint.
Will keep posting.
HMS SOTS
HMS Victory
HMS Surprise
#40 Posted : 19 August 2013 22:06:53
She's looking good, very well done....Cool Cool
5 Pages <1234>»
This page was generated in 0.211 seconds.
