Cheers lads for the comments appreciated. Just like to point out the dummy cannon I made was for the tutorial, so I thought I`d show you my original dummy 1/72 32 pounder cannon barrel, as you can see by the pics you cant see the split, its hidden behind one of the cannons rings, willz attached the following image(s):
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Excellent work Willz Regards Alan England expects that every man will do his duty.
Incredible piece of work.
John
cheers for the comments lads. been a bit too warm for me haven`t done much, just a small update on the barge, couple of pics of where I`m at, been trying to figure out how to do the tiny gratings, all efforts up till now failed. oh well, keep trying willz attached the following image(s):
Joined: 31/12/2011 Posts: 123 Points: 369 Location: Graz, Austria
These details are really amazing and without comparison to everything I've seen so far (well, with the exception of your own work). Do you still use deAgo's parts as a basis (or at least for taking measurements) or is it completely built from scratch?
Beautiful work once again Willz, now that is what I call a launch....  .. Very well done... Regards Alan
Lovely work and detail Willz I must say, seeing the picture of the launch in your hand, brings home how large the De Ag kit is compared to my 1/100 scale kit. Re the grating, I know you like to scratch build, but have you considered buying pre made, I have used 1mm square grating and I know they make larger sizes too. Keep up the great work. Regards Alan England expects that every man will do his duty.
Bernd wrote:These details are really amazing and without comparison to everything I've seen so far (well, with the exception of your own work). Do you still use deAgo's parts as a basis (or at least for taking measurements) or is it completely built from scratch? hi Bernd, its completely scratch, all drawings taken from john McKay`s book. Still have all the mags from the deag Victory, the idea was to build the deag out of the box painted at the same time as building a 1/72 scratch natural finish. mmmmmmm seemed a good idea at the time. cheers
sparks wrote:Lovely work and detail Willz I must say, seeing the picture of the launch in your hand, brings home how large the De Ag kit is compared to my 1/100 scale kit. Re the grating, I know you like to scratch build, but have you considered buying pre made, I have used 1mm square grating and I know they make larger sizes too. Keep up the great work. Regards Alan hi Alan managed to do the gratings, bit tricky but got there in the end. the picture of the boat in my hand is a 1/72 barge and not the de ag launch, so below is a pic of my de ag launch just for comparison willz attached the following image(s):
Really well done on the gratings Willz  Thanks for the heads up on the launch, but even at 1/84 its a fair bit larger than mine will be. Regards Alan England expects that every man will do his duty.
There's no denying it, a masterpiece or should that be masterpieces. Beautiful work Willz, beautiful work. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Indeed it is wilz, beautiful.
John
Thanks for the comments lads, appreciated. Managed to fit the gratings to the barge, quite pleased with the outcome, must admit I had a hard time making the gratings, the problem was the fact that I wanted thin stock about .5 mm and to cut a steady .5 mm on the saw after grooving the material didn't work so I ended up making them out of strips (tricky) anyhow I will show a complete tutorial of how I made them later this week. Cheers willz attached the following image(s):
Hi Willz  , Those gratings look real good  . Can`t wait for the tutorial Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Willz  , Those gratings look real good  . Can`t wait for the tutorial Regards delboy271155 (Derek) I agree, they look as good ,if not better that anything you can buy. Great work Willz Regards Alan England expects that every man will do his duty.
Outstanding and simply beautiful... best I've seen.... Regards Alan
Joined: 12/04/2012 Posts: 29 Points: 87 Location: Melbourne, Australia
Great detail Willz.  Perksy
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
wow i must say theres some great work in this build, love the work with the boxwood, i'll be keeping a close eye! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Thanks for the comments all, appreciated. OK on with the gratings, I put a saw blade in my circular saw .5 thick, then ran a groove down a piece of 6 mm ply and glued a . 5 mm strip in the groove, then next to the strip I cut out a hole to take my circular saw blade, the hole is wider than the saw as to adjust from the strip (fence) for larger or smaller holes in the gratings. Fixed the ply to my saw and adjusted for a 1.3 mm hole. willz attached the following image(s):
Next cut some .5 mm X 2 mm strips to about 20 mm in length, these are the pieces I will use to make the gratings willz attached the following image(s):
Guest (23)
