162 Pages «<7475767778>»
#1501 Posted : 07 August 2013 23:48:42
Tonight I finished all the work on issue 41, that is fitting the box section to the underside of the stern gallery and the three small framing pieces under the side galleries...
#1502 Posted : 07 August 2013 23:57:16
Started work on issue 42. Sanded and prepared the bow to take the bow deck... removed the bow deck from the fret and gently sanded the edges to remove the ash.. Cool .. Test fitted the bow deck and further sanded the edges to get a nice fit. Glued the bow deck in place ensuring the bow spirit dowel was in situ...Cool Cool
Took the bow bulkhead lower frame, sanded the edges and also using a half round file grooved the underside to ensure the bow spirit dowel would slide in without interference. With the lower framing in place I traced round it and removed it and the dowel... Blink Blink .. Instructions called for staining the bow deck to mimic the sapele so once again decided to use the real thing and planked it.. This added .5mm height but don't see that causing too many problems.... Cool Cool ... Will continue tomorrow planking the forward bulkhead and here I intend to deviate slightly from the official build.... Cool Cool
Happy building all
NMBROOK
#1503 Posted : 08 August 2013 00:08:32
Lovely work AlanCool I bet you are enjoying yourself with some proper construction as opposed to treenailing and gunport lining.
Out of interest,my reference material suggests they were glazed and they opened in two halves vertically.I originally went for 1mm mesh as this was very close to scale size of the leaded windows in Temple Newsam house which is late 16th century and still has the original windows.
Kind Regards Nigel
#1504 Posted : 08 August 2013 00:18:23
Kind Regards Nigel
Thanks Nigel and yes, it is great getting on with some varied construction work and looking forward to planking the forward bulkhead.... Cool Cool .. My thinking on this and looking at the Italian forum is to extend the planking to another 16mm above the top support, this would result in not having an unsightly deck line showing. It also means I would have to remove the front 2mm from the deck to compensate for the thickness of the planks. I intend to plank the bulkhead in walnut and not use the bamboo mainly as the walnut has nice straight edges and not rounded as with the bamboo... Walnut will be stained further to really darken it down but will still be able to see the grain....Cool Cool .. Thanks also for the heads up on the windows, will also play around a little using Krystal Kleer to see how it would turn out if I was to apply it to the fine mesh...BigGrin BigGrin
Thanks again for the nice comments and your continued support, really is appreciated...
#1505 Posted : 08 August 2013 08:33:49
BigGrin Hi Alan I also planked the bow and have no probs with the rest of the build BigGrin Love the work rgd Martyn
#1506 Posted : 08 August 2013 10:30:56
Thanks Martyn, appreciate the confirmation....
Admiral Anti Spiral
#1507 Posted : 09 August 2013 11:39:05
lovely work alan, looking great BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1508 Posted : 09 August 2013 12:04:23
Thanks Admiral, now simply plodding along just nicely...LOL LOL .. Hope to post an update this evening... Cool Cool
der Gohfelder
#1509 Posted : 09 August 2013 16:25:47
H Alan!
A really nice work and progress! ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
Regards, Bernd
#1510 Posted : 09 August 2013 17:22:05
Hi Alan, great job you are doingBigGrin Kind regards Mike
#1511 Posted : 09 August 2013 20:17:56
Your planking looks great, very nice build as ever
#1512 Posted : 09 August 2013 22:13:01
der Gohfelder wrote:
H Alan!
Regards, Bernd
Thanks for you kind comments Bernd, always appreciated.... Cool Cool
#1513 Posted : 09 August 2013 22:14:07
Thanks for the positive comments Mike, always good to hear from you.... Cool Cool
#1514 Posted : 09 August 2013 22:15:07
Appreciate your positive comments Jase, thanks for looking in.... Cool Cool
#1515 Posted : 09 August 2013 22:17:47
Been a funny day today with some of my efforts being a success whilst others not so good... Crying Crying .. Made attempts at darkening down the walnut keel to get a closer match to the hull.... Settled on using a medium oak as it was the closest I could get.....Blink Blink
#1516 Posted : 09 August 2013 22:20:41
Finished applying the planks under the starboard gallery, sanded down and masked off ready for painting tomorrow..... am pleased with how it looks so far.... Cool Cool
#1517 Posted : 09 August 2013 22:26:24
Planked the bow bulkhead using 2mm thick walnut but first darkened down the walnut using a walnut stain... I liked the look of it as it allowed the grain of the wood to show through.... Cool Cool .. I really didn't fancy the idea of a deck line running across the front bulkhead so added an additional 18mm to the plank height realising this would mean I would have to remove the front 2mm from the deck... Cool .. Once finished I took a long look at the results and quite frankly didn't like it..... Blushing Blushing .. Think the walnut just looks out of place so tomorrow it is going to be painted black..... Ah well, we learn by our mistakes..... Blushing Blushing
#1518 Posted : 09 August 2013 22:31:26
Finished off todays session by applying sapele planking to the forward section of the prow framing, didn't see the point of staining to look like sapele....BigGrin ... also lined the holes with .5mm basswood ready for the 1mm gratings.... happy with the results so the day ended on a positive note.... Cool Cool
NMBROOK
#1519 Posted : 09 August 2013 23:03:25
Lovely work AlanCool Cool looks like you have been a busy beeBigGrin Good thinking regards the deck edge,I don't know why they didn't design it to sit inside the plankingHuh
Kind Regards Nigel
#1520 Posted : 09 August 2013 23:27:02
Kind Regards Nigel
Thanks Nigel, agree with you regarding the deck edge.. Don't think it's a big issue regarding the side bullworks so can live with it, not so the bow bulkhead..... BigGrin BigGrin .. Today was good, just a shame the walnut staining didn't turn out as I had hoped, just goes to show you never know how something turns out until you actually try it.... Cool Cool .. Black paint to the rescue.....LOL LOL LOL
Guest (12)
This page was generated in 0.789 seconds.
