30 Pages «<23456>»
Stevie's Vic Build Options
karl josef
#61 Posted : 21 July 2013 17:08:26
the figures,fantastic
Best regards,
Reiner
#62 Posted : 07 August 2013 21:52:13
Thanks for the comments guys.
Just to let you know I am still progressing with this but slow going as I still receive the parts each month so im restricted to how fast I can go.
Anyway, I have now painted all 80 something HAT figures and completed the main and fore mast and all 6 yards for these 2 masts. The mizzen mast must come a lot later in the build.
I have now wrapped these up and put them away for a while to keep them safe as its back to work on the hull now.
More pics soon.
#63 Posted : 10 August 2013 14:49:58
Just completed the entrance canopies on issue 74. After painting the trim gold as suggested in the guide, I though the channel between the two gold trim lines on the canopy supports was a bit plain so I decided to add a little more detail.
I painted 1 piece of solder black and another gold and made a twist, I then pressed these into the recessed channel, sized them up first and then glued them in.
The solder bends nicely to fit the parts and can be trimmed with a blade. A little coat of gloss varnish to complete!
#64 Posted : 10 August 2013 16:05:11
nice touch BigGrin
sparks
#65 Posted : 10 August 2013 18:15:37
Nice job Steve ThumpUp
#66 Posted : 10 August 2013 21:24:21
Hi Stevie, BigGrin BigGrin
Some very nice added detail in there.
Following with interest, Cool Cool
#67 Posted : 10 August 2013 23:19:48
What a fab idea to use solder, impressive work Steve.... very well done...
#68 Posted : 11 August 2013 00:12:53
BigGrin Very nice work and you have reminded me how usefull solder wire can be Steve keep it up
#69 Posted : 11 August 2013 19:43:23
Well done, Steve looks brilliant and good tip.
#70 Posted : 31 August 2013 15:38:25
Hi Everyone, just been plodding along with this up to issue 80 now, not much to report so i will just pop some pics of all the new additions since the last entry, pictures speak louder than words, or so they sayBigGrin
Gaz
#71 Posted : 31 August 2013 15:57:31
Hi StevieBigGrin
Looks fabulous. Keep up the good work.
Regards.
Gareth
z8000783
#72 Posted : 31 August 2013 16:41:54
Groups: Unapproved
Beautiful paintwork, another masterpiece looms.
#73 Posted : 01 September 2013 00:49:55
Hi Stevie, love it, so clean and precise.... Very well done... BigGrin BigGrin
Whitesd
#74 Posted : 01 September 2013 10:07:40
Hi Stevie,
Earlier on in your build you mentioned that you used "weather it" on your deck planking, as well as Danish oil. I think that your deck planking is absolutely stunning and just wondered if you had any more info on the "weather it" and Danish oil. We are a little isolated in South AfricaAngry.I'd like to find out if there is anywhere here that I could get the stuff. Love your Victory BigGrin
Present Build: San Fransisco II, 1/32 Lancaster Bomber
Subscribed to: Sovereign of the Seas
Completed: La Toulonnaise, Harvey
calv
#75 Posted : 01 September 2013 10:15:18
Stunning build an excellent touch using solder on the hatch.
Ongoing Builds
Deag HMS Victory
Deag Soveriegn of the Sea
#76 Posted : 01 September 2013 13:30:13
Thanks all so much for the nice comments, more pics to come soon when i get my next installment.
Re. The deck planking, this is what i did exactly -
After the deck were smoothed down I applied a 50/50 mix of "weather it" and water.
I got mine from ebay from this seller - http://www.ebay.co.uk/itm/Weath...&hash=item589b024322
it does seem expensive but it will last you for years and many models!
This was left to age the wood overnight then I painted on the Danish oil. You can get this in many brands but i used the cheapo one at Wilkos for about £4 for big tin, this will also last you for many models. I know you wont get the exact one if you are in SA but here is the one i got so you can get an equivilent - http://www.wilko.com/garden-fur...65151?VBMST=danish%20oil
Then, the next day I did 2 coats of waterbased matt varnish, this dries very fast and i did both coats a hour apart - any varnish will do im sure but again i went for "cheap" and got wilkos here - http://www.wilko.com/interior-w...017?VBMST=matt%20varnish
The varnish, although says matt will add a very slight sheen to the wood, a little more on each coat, i liked the effect after 2 coats so stopped there.
Hope all this helps
Cheers
Jesus-Belzheim
#77 Posted : 05 September 2013 18:46:52
Excellent Work Stevie ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#78 Posted : 05 September 2013 20:03:57
BigGrin Top work SteveCool
NMBROOK
#79 Posted : 05 September 2013 22:06:00
Fantastic build SteveCool Cool The entry ports look amazing,very clever use of solder.
Kind Regards Nigel
#80 Posted : 08 September 2013 22:51:49
Well done Steve, and a well earned 'outstanding build' yellow medal Cool
30 Pages «<23456>»
This page was generated in 0.577 seconds.
