issue 80 cross jack yard Options
cal
#1 Posted : 10 August 2013 18:21:50
Could someone tell me if the 2 yard slings provided with issue 80 are the right size because comparing them to tge drawing they are much smaller ... Thanks cal
cal attached the following image(s):
#2 Posted : 10 August 2013 19:01:28
hi cal, looks alright to me,don't forget that ,that is a top view,so the overhang does not show on that drawing, k.
#3 Posted : 10 August 2013 19:18:12
I think they are a bit small do you have some larger ones?. the pale rectangle is the footprint of the part the extending black line is the top of the part representing the overhang - or at least that is how I have understood it, just like a technical drawing view. I just did the main mast spar today and my part fitted to the plan.
cal
#4 Posted : 10 August 2013 20:14:16
The rest have fitted the drawings .... what do they actually do and will it matter uf they are a bit smaller
#5 Posted : 11 August 2013 20:30:46
I think they are used for fitting them to the mast. can you not fabricate replacements from some scrap?
cal
#6 Posted : 12 August 2013 16:31:04
Sound's like a plan ....Thanks jase and Karl
This page was generated in 0.037 seconds.
