25 Pages «<1415161718>»
Claret's SOTS Build Diary Options
Admiral Anti Spiral
#301 Posted : 06 August 2013 23:38:59
a good choice of red claret, looking good!
Processing - Progressing
Previous builds: HMS Victory
claret
#302 Posted : 07 August 2013 08:03:08
Hi Dominic,
I did not measure the paint, but put small drops of water and mixed until the 'milky' effect was achieved. Not very sceintificLOL
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#303 Posted : 07 August 2013 08:05:31
Hi Alan, Nigel & Admiral,
Thanks for your kind positive comments. I am pleases with the result, and now waiting for the courage to do the main hull white.
The red ochre, on the canon port surrounds looks great. I will post pics later this evening.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#304 Posted : 11 August 2013 15:11:08
Hi,
I decided to tree-nail the gunwale's before painting and fitting. I then spray painted them matt black. I had previously measured and cut all the gunwales ready for fitting. the pics show a few of them.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#305 Posted : 11 August 2013 15:13:40
Hi,
I had opted for the 1mm CMB gratings and thought I would show a photo comparing the 2mm build grates to the 1mm build grates. The 1mm are of a far better quality.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#306 Posted : 11 August 2013 15:55:37
Fabulous work ClaretCool Cool I think the caldercraft 1mm compared to the standard ones are like chaulk and cheese.The only hassle I find with the 1mm ones is that whatever timber they are made of,it's ROCK hardLOL
Kind Regards Nigel
claret
#307 Posted : 11 August 2013 17:54:09
Hi Nigel,
Thanks for looking in.
Yes, the 1mm wood is extremely hard, but well worth the perseverance of cutting.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#308 Posted : 11 August 2013 20:12:18
Lovely stuff there Claret, good job.
KobusBeukes
#309 Posted : 11 August 2013 20:29:03
Hi Claret
Thanks for posting a picture of the supplied grating and the 1 mm grating!
Now all can appreciate the 1 mm grating! Looks really good! LOL LOL LOL
Kobus
Current Build
claret
#310 Posted : 11 August 2013 20:48:45
Thanks Hans & Kobus,
The only issue with the 1mm grating is the largest size available is 33mm square.
Some modifying of the bow beak is required, but the deck openings look like they maybe okay.
Confused
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#311 Posted : 11 August 2013 22:43:55
Nice work Claret...Cool Cool .. As you say, 1mm grating kits only come in a size to cover 33mm, rather than modify the deck framing I am now looking at modifying the gratings by using 2 sets to extend the size.... will see how it turns out before I go modifying the framing.....Cool Cool
claret
#312 Posted : 12 August 2013 08:09:01
Hi Alan,
Thanks.
Will be interesting. I thought of doing that with the grates, but thought it was a lot more work. That said, modding the frame a lot more work aswellLOL I think any mod turns out that wayBigGrin
Look forward to seeing the results.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#313 Posted : 13 August 2013 22:56:35
Hi,
I have now finished the hull painting in dull white from the admiralty SOTS set. Airbrushed it after buying a compressor, giving a few coats, but did the last coat by brush.
Results below:
Also started lining the gun ports. Airbrushed in red Ochre before cutting and gluing into place.
I am happy with the outcome of the white hull.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#314 Posted : 13 August 2013 23:00:45
Lovely work Claret, superb job you are making of lining the gun ports... found that part of the build to be very tedious after a while but got there in the end as you will... Cool Cool .. Keep it going...
#315 Posted : 13 August 2013 23:02:29
Loverly finish on the hull, well done Cool
claret
#316 Posted : 13 August 2013 23:02:32
Hi,
Now the hull is finished, I started on the gunwales. I have only glued the first part of the top side of the port side.
Glued in place, but used the Hornby railtrack pins to hold in place. Being black, I left the heads on to hold the gunwale better and also, they look like studs.
My progress so far shown below:
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#317 Posted : 13 August 2013 23:06:45
Hi Jase & Alan,
Thanks for looking in and thanks for the kind comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#318 Posted : 13 August 2013 23:54:16
She's looking fabulous claretCool Cool superb finish!
Kind Regards Nigel
claret
#319 Posted : 14 August 2013 08:04:49
Thanks Nigel,
Much appreciated.
Planning to have the gunwales finished by the weekend.
Will post full assembly then.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Admiral Anti Spiral
#320 Posted : 16 August 2013 12:10:37
wow lovely hull claret looks very nice and clean and sharp, beautiful work!BigGrin
Guest (8)
This page was generated in 0.637 seconds.
