162 Pages «<7677787980>»
#1541 Posted : 13 August 2013 10:20:57
Plymouth57 wrote:
Hi Alan.
That grating is superb! a lovely job and well worth the time put in it. Incidentally, I was looking at the smaller prow grating you made first, I counted 85 separate pieces in it! I didn't bother on it's big brother! Blink (actually I kept losing count and gave up!)Flapper
Very well done.
Thanks for the kind words Robin, appreciated...Cool Cool .. You obviously have too much time on your hands if you have the time to sit there and try to count the parts....LOL LOL Flapper Flapper .. All I know is there were a lot of parts to put together for both sections..... Cool Cool
#1542 Posted : 13 August 2013 10:22:00
der Gohfelder wrote:
Hi Alan!
Very nice gratings, well done!
Regards, Bernd
Thanks Bernd for looking in, appreciate it.... Cool Cool
#1543 Posted : 13 August 2013 10:24:36
claret wrote:
Hi Alan,
Great work, tried but can not see the seam where the two grates joint. Top job, welldone.
Claret
Thanks Claret, the reason you cannot see the seams is because the joints are actually on the spars underneath running top to bottom, the cross spars fit the width without the need for any joints.... Cool Cool.. If I turned the piece the other way up then you may see them.... BigGrin BigGrin
#1544 Posted : 13 August 2013 10:26:11
jase wrote:
first class build really nice results your achieving. love watching your build come together
Hi Jase, appreciate the nice comments from you.... very pleased you are enjoying watching the build.... makes it all worthwhile in keeping the diary.... Cool Cool ..Thanks again,,
#1545 Posted : 13 August 2013 11:32:49
Just noticed I have fitted two of the centre sections with gratings and these should have been left empty....Mad Mad .. Have now cut them out and cleaned up the inside edges....Blushing Blushing .. Lesson learnt, read the instructions and read again......Blushing Blushing
#1546 Posted : 13 August 2013 21:57:15
Today I finally got round to planking the underside of the portside gallery, first thing on the agenda for tomorrow is to trim, sand and give it a coat of pain....Cool Cool
#1547 Posted : 13 August 2013 22:01:28
Did some work on the beak, first thing was to fair the tops of the ribs to ensure a smooth fit for the decking.. Cool Cool ... Painted the beak black and also gave the bow deck a coat of matt clear varnish...Cool Cool .. Finally dry fitted everything to see how it all fitted and looked.... am happy with the results...BigGrin BigGrin .. Hopefully will get the deck fitted along with side panels tomorrow... Cool Cool
Happy building all..
NMBROOK
#1548 Posted : 13 August 2013 22:01:35
Coming on well AlanCool Will that enable you to paint the rest of the stern?Just wondered,as you know I aren't using the instructions.
Kind Regards Nigel
#1549 Posted : 13 August 2013 22:08:22
Kind Regards Nigel
Thanks Nigel, the instructions don't call for it just yet but I don't see any reason why it can't be painted now so will probably do that tomorrow when painting the underside of the gallery... To be honest, the instructions don't call for the side galleries to be painted yet either... Will see how tomorrow works out.... Cool Cool
claret
#1550 Posted : 13 August 2013 23:14:34
Hi Alan,
That is looking really goodDrool
The beak sets it off nicely.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1551 Posted : 14 August 2013 00:13:50
claret wrote:
Hi Alan,
Claret
Hi Claret, thanks for the positive comments and for looking in... appreciated.... Cool Cool
Admiral Anti Spiral
#1552 Posted : 16 August 2013 12:08:57
looks great alan lovely work with the treenailng there, looks very nice, well done!BigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1553 Posted : 16 August 2013 21:38:33
Progressing slowly but am now happy to say I have completed issues 42 and 43. Sanded down the planking on the underside of the portside gallery, when happy gave it a coat of matt black paint... As the paint was out I also decided to take the opportunity to paint the stern panel including the inner side.... Still needs a second coat but that will be done before fitting the ornamentation... Cool Cool .. Whilst working in this are I also decided to tidy up the sapele planking on the stern, removing two of the strips than had become damaged.... only thing left to do here is to treenail.... happy with the results so far... Cool Cool
#1554 Posted : 16 August 2013 21:44:32
Fitted and painted the side panels on the beak. Wasn't too happy with just the inner panel being painted so decided to plank it using .5mm basswood, think it looks a lot better. Finished off by fitting the 1 x 3mm strip to tidy everything off.... Cool Cool .. Also gave the sapele strips along the hull a coat of matt clear varnish and intend to give it another coat yet.. BigGrin
#1555 Posted : 16 August 2013 21:49:54
Cut the 6 deck sections free from the frets and sanded all the black ash off.. Carried out a dry fit and found they fitted with very little problems or alterations however, I did feel the ports on the centre section were just a touch too low for my liking, by about 1mm.. Will have a closer look tomorrow but think my intention is the lower the deck, this method creates the least amount of disruption and by the time it is finished I do not think it will be noticeable... Blushing Blushing .. Will post details of the fix as I progress....
#1556 Posted : 16 August 2013 22:21:16
Thanks Admiral, appreciate the kind comments...
#1557 Posted : 17 August 2013 18:26:18
BigGrin Bril work Alan Love it BigGrin Rgd Martyn
NMBROOK
#1558 Posted : 17 August 2013 19:12:23
Lovely work AlanBigGrin The prow looks great.
Kind Regards Nigel
#1559 Posted : 17 August 2013 21:48:53
Thanks for the kind comment Martyn and for looking in.... Cool Cool Appreciate your support....Cool Cool
#1560 Posted : 17 August 2013 21:50:50
Kind Regards Nigel
Thanks Nigel, have to admit I am pleased with the way it has turned out....BigGrin BigGrin .. Not sure whether to plank to outside of the prow panels so have decided to leave it as is until the ornamentation of this part makes an appearance... can be done at a later date if necessary... Cool Cool .. Thanks again...
Guest (12)
This page was generated in 0.350 seconds.
