Joined: 10/10/2012 Posts: 66 Points: 191 Location: UK
I have been reviewing Mr T's and Andy's build diaries and I see that they replaced the supplied wire with 1 mm strips. I have been trying to find where to purchase this in the UK. Can anyone help me? Thanks again for all your support. Current Builds: Yamato On the Bench: Akagi, USS Missouri
 Hi Db What your after is and what we both used was 'Evergreen Scale Models' StripStyrene .020x.040 inch [0.5 x 1.0 mm]size its available at Hobbystore branches or from online model shops you will need about 40 strips or 4 packs to do the Yam with some left over. Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy, Thanks for the info. Just a quick question, I assume you are talking about it being a rectangle, do you have a part number by any chance. All I can find are Styrene Rods, circular. All help appreciated. Thanks again, Dan Current Builds: Yamato On the Bench: Akagi, USS Missouri
Hi Dan this may help http://www.cornwallmodel...catalog/plasticard.html
“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Dan Item no 122 for the strip and for the brackets I used No 10 staples bent over a 1mm metal sheet to get the shape Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
