Stern planks Options
RobT
#1 Posted : 17 August 2013 21:14:04
Just want to double check, after trimming the sides, I'm left with a planking protrusion above the gallery. Do I just level off even with the gallery?
#2 Posted : 17 August 2013 21:40:14
In essence yes, but you can leave until you do the height markings where the heights are then adjusted.
RobT
#3 Posted : 17 August 2013 21:47:57
Do you mean issue 35, stages 4-10?
If so, I've done that, but the issue doesn't make it clear about trimming the tops of the last planks.
Or is there an even later stage I'm not aware of?
Marcel
#4 Posted : 18 August 2013 09:49:27
I looked into the Italian forum for future issues. They have the issues that you can download. I saw a picture of some cutting, not sure which issue.
Italian forum (clik here)
Marcel
Sovereign of the Seas
#5 Posted : 18 August 2013 10:12:33
Marcel, you need to be aware that there are slight changes between the Italian and English instructions.
#6 Posted : 18 August 2013 10:13:21
Correct Rob, complete as per how you see it at step 28
RobT
#7 Posted : 18 August 2013 12:08:24
Cheers fella,
I can see it clearly now. I'll level it off.
This page was generated in 0.281 seconds.
