162 Pages «<7778798081>»
#1561 Posted : 17 August 2013 21:55:16
Ok, so now we make a start on issue 44. First thing I did was to dry fit all of the deck sections and to have a close look at how it all sat...BigGrin Very first thing I noticed was the main deck gun ports on the port side was fine however the ports on the starboard side were sitting a little low for my liking and this needed to be tackled or it would constantly annoy me Blushing Blushing .. As the pic shows, there isn't a lot of room there for the deck planking plus the walnut edging to fit under the ports... Blushing Blushing
budgie
#1562 Posted : 17 August 2013 22:01:28
Drool Drool Great lookin' build Alan coming along nicely Sir
LOL My parts are still under lock n keyLOL
#1563 Posted : 17 August 2013 22:07:55
So now I had some decisions to make in order to put the ports right... I could move the ports but that would mean moving all of the top row of ports to ensure I retained the balanced flow line... this would be a lot of work and could cause damage along the way... ruled this option out... Blink Blink .. I could leave things as they are but it would niggle me so that is just not acceptable to me either...Blink Blink .. The only option left was to lower the deck on the starboard side, this would need to be done by about 2mm and it is not something I think would be noticeable, this is the option I have chosen.. Cool Cool Having decided to lower the deck I had to also ensure I did not alter the heights of the forecastle or quarterdecks.. I cut out the framing for the bulkheads, dry fitted with sections of the deck planking I will be using placed underneath, once happy I marked off the heights of the forecastle and quarterdeck...
#1564 Posted : 17 August 2013 22:10:19
Thanks very much for the positive comments Budgie, appreciated and thanks for taking the time to look in... Cool Cool
#1565 Posted : 17 August 2013 22:15:03
Next stage was to remove the decking and to cut and dry fit the deck supports... ensured all of the supports were a snug fit and also took the time to number them.... Blink Blink Using a new blade I then trimmed down the ears on the ribs by the required 2mm, did this very carefully taking small slivers of wood off at a time... When down to the correct height I then filed down the deck support by the same amount and again test fitted.... Cool Cool
#1566 Posted : 17 August 2013 22:21:27
Continued to do the same with all the ribs along the centre section.. I also realise this method means I will have weakened the deck supports so to compensate I intend to add additional supports underneath. This will not be noticed when its complete.. Finally, did a dry fit of the decks again and was a lot happier with the results... Cool Cool .. I appreciate there are many ways to deal with this common problem but hopefully by outlining my method it will be of help to others behind me who may find they have a similar problem.... will continue with the fix tomorrow and post the results..
Happy building all...
#1567 Posted : 17 August 2013 22:22:28
BigGrin Hi Alan
Your certainly doing some major rebuilding to get things right but as you say it will only irritate you everytime you look at her ,hope it all works out and your doing a fine job
#1568 Posted : 17 August 2013 22:26:05
BigGrin Hi Alan
Thanks Andy, happy to say so far it is working out for me... Huge lesson learnt here, once you start cutting ports then always double check the heights in relation to the deck level on the upperdecks... Won't make that mistake again I can tell you..... Thanks again for looking in.... Cool Cool
NMBROOK
#1569 Posted : 17 August 2013 22:32:42
Excellent fix AlanCool Cool well done mate,would of done it that way myself.Looking at that fab planked deck inside reminds me of how many moons ago that was,I had almost forgotten about it.No I am not saying your slow,but it's surprising to think we subscribed to this a year ago.
Kind Regards Nigel
#1570 Posted : 17 August 2013 22:48:36
Kind Regards Nigel
Thanks for the positive endorsement Nigel, heart in mouth for a while as I just wasn't sure how it was going to turn out, not that its finished yet, still have more to do but just knew I couldn't leave it as it was....Cool Cool .. And yes, that decking was done some time ago before the planking even started, it was done as a practice having never done it before... I'm pleased with it but shame you won't see it but hey ho!!!... To think issue 50 is just out in the newsagents and I am on issue 44, we are not yet even half way through.... long way to go yet eh.... Cool Cool Thanks again....Cool Cool
KobusBeukes
#1571 Posted : 18 August 2013 07:04:43
Hi Alan
Excellent fix and thanks for sharing! I'm glad we're so far behind that we get all the heads up on all the 'problems' and then the excellent fixes!
Kobus
Current Build
#1572 Posted : 18 August 2013 11:21:17
KobusBeukes wrote:
Hi Alan
Thanks very much Kobus, if it helps other builders then I am happy to share.... Cool Cool
#1573 Posted : 18 August 2013 11:59:00
Hi Alan,BigGrin
Cool fix on the deck height, WTG Cool
der Gohfelder
#1574 Posted : 18 August 2013 12:21:42
Hi Alan!
You found a good solution for your problem, well done !
Best regards, Bernd
B Johnson
#1575 Posted : 18 August 2013 14:19:38
Amazing work so far, I bet you have put some hours into this! Would you recommend this kit? Thinking of getting it after collecting the Hood
Current Builds: Amati 1/200 Bismarck, Airfoil 1/600 HMS Nelson
To Build: Amati 1/200 HMS Hood, Amati 1/250 Titanic, Artesania Latina 1/48 HMS Surprise, Artesania Latina 1/50 Scottish Maid, DeAgostini 1/84 Sovereign of the Seas
#1576 Posted : 18 August 2013 21:57:24
delboy271155 wrote:
Hi Alan,BigGrin
Thanks for the kind comments Derek... Cool Cool Shouldn't have needed fixing in the first place, careless of me.... Blushing Blushing
#1577 Posted : 18 August 2013 21:58:25
der Gohfelder wrote:
Hi Alan!
Best regards, Bernd
Thanks Bernd, appreciate the kind comment... Cool Cool
#1578 Posted : 18 August 2013 22:01:02
Appreciate the positive comments Ben and for you taking the time to look in.... Cool Cool .. A lot of hours have been spent on her so far and I would wholeheartedly recommend this kit, its a beautiful build.. The kit like all kits has its own problems all of which are being well documented on this forum.... BigGrin BigGrin .. Think you would enjoy this one..... Cool Cool
#1579 Posted : 19 August 2013 08:19:33
BigGrin Well done on the fix Alan bril BigGrin Rgd Martyn
#1580 Posted : 19 August 2013 21:49:29
Thanks Martyn, fix is ongoing but going well.... Cool Cool
Guest (12)
This page was generated in 0.487 seconds.
