12 Pages «<34567>»
Kobus' SOTS Build - SA Options
#81 Posted : 11 August 2013 19:52:26
Well done Kobus, looks briliant.
Captain David
#82 Posted : 11 August 2013 19:59:57
Good practice with the staining of the bowsprit, Kobus - but it will not be seen in the final build.
KobusBeukes
#83 Posted : 11 August 2013 20:18:29
Hi Catain David
I saw Alan covering his bow spirit with walnut sheets and decided, as I have 3.2 mm walnut available, that I would cut mine out of solid walnut. I'm in between deliveries so have some spare time available to experiment. BigGrin
I didn't know that it would not be visible in the final build, but thanks for the info!BigGrin
Kobus
Current Build
KobusBeukes
#84 Posted : 11 August 2013 20:21:22
Thanks for the nice feedback Hans! BigGrin
Kobus
Current Build
#85 Posted : 11 August 2013 22:32:40
Nicely done Kobus..Cool .. The reason I covered mine with walnut sheet was because I covered the keel to match the hull so just continued all the way rather than just simply cut it where the black starts, neater that way..... Cool Cool .. I am probably going to paint it black anyways..... Cool Cool ..
KobusBeukes
#86 Posted : 12 August 2013 06:03:12
Hi Alan
Thanks for the nice words and the advice BigGrin , much appreciated!
Kobus
Current Build
Marcel
#87 Posted : 18 August 2013 18:34:43
BigGrin
Neat lines on your Launch. Love I am thinking of double plank the launch in Sapele. As a Newbie, I made a mess of the first try.Crying Its resting in a safe place to be commence on a much later date.
Meanwhile am I focusing on the actual boat. I want to do all the smaller builds at once.
My friend around the corner of me is also building the SOTS. I am fortunate to share consumables with him. I am at issue 19 now. I bought extra issues for the sake of stocking wood supplies.
I want to buy extra figurines when they arrive here. According to the Italian forum, SOTS do have great figurines. I want to salvage some Victory figurines for my collection.
If you came across them, PM me.
Regard
Marcel
Sovereign of the Seas
KobusBeukes
#88 Posted : 18 August 2013 22:03:42
Hi Marcel
Thanks for the nice comments on the launch! Much is hiden behind the woodfiller and paint! As I was going for the painted finish on the launch I use some woodfiller to smooth out the planking. Must say I'm happy with the outcome!
Kobus
Current Build
#89 Posted : 19 August 2013 08:17:35
BigGrin Nice work on the launch Kobus BigGrin Rgd Martyn
KobusBeukes
#90 Posted : 19 August 2013 08:42:42
Hi Martyn
Thanks for the nice words! BigGrin
Much appreciated!
Kobus
Current Build
KobusBeukes
#91 Posted : 21 August 2013 22:25:20
!!!LOL Update LOL !!!
Received my next four issues (16 - 19) today, BigGrin with my mitre set and mini clamps!BigGrin Thanks Jacklin!BigGrin
Started with the stern planking and it came out nicely (will post some photos tomorrow)!BigGrin
Must say, expected the bamboo to be much harder to work with and more knots in, unless I got a better bunch! BigGrin
Kobus
Current Build
#92 Posted : 21 August 2013 22:50:26
Hi Kobus, at least with these 4 issues you'll be kept busy for a while.... look forward to seeing your progress...Cool Cool
KobusBeukes
#93 Posted : 22 August 2013 05:54:28
Hi Alan
Thanks for the encouragement, will post some pics tonight!BigGrin
Kobus
Current Build
KobusBeukes
#94 Posted : 22 August 2013 18:57:14
Photo Update!
The stern finished planking!
Kobus
Current Build
#95 Posted : 22 August 2013 19:34:39
Hi Kobus,BigGrin
Looking good, just one bit of advice (from my view).
Your fifth plank down on the stern is bending round the stern post.
I don`t think it needs removing, just a sharp knife to cut a small
notch around the false keel section.
This should make your second planking much easier around that area.
Keep up the good work. Cool
#96 Posted : 22 August 2013 19:39:45
Yes I agree probably just needs a 1/2 mm slither removing
KobusBeukes
#97 Posted : 22 August 2013 20:48:53
delboy271155 wrote:
Hi Kobus,BigGrin
Hi Derek and Jase
I've noticed the bend and thought I would sand it down to the other planks, but must agree if I cut a small notch around the false keel it would work much easier!BigGrin
Thanks fot the advice, much appreciated!BigGrin
Kobus
Current Build
Marcel
#98 Posted : 22 August 2013 21:20:59
Well done Kobus, your build is coming on smooth. BigGrin
Issue 20 is on the shelves at CNA. Grab an extra issue for the wood supply. Its cheaper than to order online.
I admit that the first row at the bow is time consuming. I keep splitting the ends and have to start over. I noticed that some of the pins supplied, are blunt or croocked.
The deck line take al lot of mini clamps and patience.
I only recieved my mitre set. Hope to recieve the clamps with my next batch.
#99 Posted : 22 August 2013 22:46:15
Nicely done Kobus, have to agree with Derek though, cut a small notch in that 5th plank to get a better fit around the false stern post... I think if you try to sand it down as you suggest then you may find you will end up sanding through the bamboo strip....Cool Cool .. Nice work though, well done.....Cool Cool
KobusBeukes
#100 Posted : 23 August 2013 05:57:00
Hi Marcel
Thanks for the nice comments!
I've already got myself a copy of issue 20 as a spare. I've used a Dremel fitted with a flexible shaft and a 0.5 mm drill bit and predrill the bamboo. It worked like a charm!BigGrin
Kobus
Current Build
12 Pages «<34567>»
This page was generated in 1.683 seconds.
