Built My Keel Jig At Last! Options
MadDogMcQ
#1 Posted : 15 June 2010 00:12:46
After eventually getting all the keel parts, I built my keel jig tonight. Now I might start getting some work done!
Quentin Tarantino - Hallowed Be Thy Name!
john burgess
#2 Posted : 15 June 2010 00:17:16
Looks like your all ready for guns blazing mad dog, must get my jig sorted will have to try and brake of "MARY ROSE"
If you dont suceed at first go to the pub
CaptnBirdseye
#3 Posted : 15 June 2010 11:41:56
Rank: Superelite
BigGrin Good start there MadDog. All those parts should keep you busy for a while!!! Not sure if i could have resisted the temptation for so long Drool
Good luck with the rest of your build!Cool
steve247
#4 Posted : 15 June 2010 14:31:24
Rank: Beginner Level 1
great jig there matey ,youll have her done in no time ow arrrBigGrin
snowtiger
#5 Posted : 15 June 2010 14:32:49
Looks like you are off to a good start there mad dog....BigGrin BigGrin BigGrin BigGrin BigGrin
#6 Posted : 15 June 2010 19:00:41
Hey!!...looking good MadDog, keep us posted on your build mate..ThumpUp
comic123
#7 Posted : 15 June 2010 19:00:43
nice jig. Finally set mine up yesterday. Used a off cut of decking I had from my dad, grooves in wood fit with of keel perfectlyBigGrin what luck.
Hopefuly with the brackets all should stay square Blink Blink
MadDogMcQ
#8 Posted : 15 June 2010 22:39:45
comic123 wrote:
Used an off cut of decking I had from my dad, grooves in wood fit with of keel perfectlyBigGrin what luck.
Actually mate, you can't allow the keel to drop into the slots on your decking board, cos the frames go right to the bottom of the keel. Huh
amipal
#9 Posted : 16 June 2010 21:58:45
Exactly, he'll need to cut some lines across for the ribbing.
Is a jig needed, or just recommended?
chrisN257752
#10 Posted : 17 June 2010 17:11:20
LIKE THE JIG SEND DRAWING
THANKS CHRIS
This page was generated in 1.907 seconds.
