10 Pages «<34567>»
AK's Sovereign Build Options
court orchard
#81 Posted : 24 June 2013 09:29:11
stujue wrote:
Hi Andy
your model looks stunning, BigGrin BigGrin , can i ask where you got your black boxwood from, os it the same size planks as the saple
cheers stu
Thanks StuBigGrin
it's pretty much the same size 0.7 x 4.5mm, so the difference is not noticeable.
from here http://www.originalmarquetry.co.../product_details_337.htm
stujue
#82 Posted : 24 June 2013 10:49:00
Thanks Andy. BigGrin BigGrin
cheers
Stu
Cheers Stu
RobT
#83 Posted : 15 July 2013 21:56:24
court orchard
#84 Posted : 16 July 2013 00:20:57
[quote=RobT]Andy. Is this the power supply?
http://www.proxxon-tools...-Mains-Adaptor-12V.html[/quote]
That's the exact one I use. I run the Proxxon Pen Sander off it too.
court orchard
#85 Posted : 31 July 2013 12:12:42
I've not been posting on this build for a while, due to medical reasons. I've explained more in my Samurai build diary.
However, I have finished the second planking and hopefully will be returning in earnest toward the end of August. The build is now getting interesting with the arrival of the first castings etc. So I'm really looking forward to itBigGrin BigGrin
As we all know, but often forget, life can have some extremely unpleasant things lurking around the next corner, so be happyBigGrin BigGrin BigGrin
Marcel
#86 Posted : 09 August 2013 11:49:38
court orchard wrote:
Hi Everybody, I have decided after much deliberation to add to the growing list of build logs. My main motivation is that I am hoping that it will keep me on track and complete this build. All comments welcome. I've never done this before so I may stumble a little to start.
Issues 1 & 2 Completed.
I follow your built for your respect to detail. After reading your green stuff solution, I went to the "Emty Room" to do some thinking. I have come up with this in following pics. Please give some ideas how to improve this look to give it the Vintage look.
Marcel attached the following image(s):
Sovereign of the Seas
court orchard
#87 Posted : 28 August 2013 16:42:53
Have finally returned from 'Zombie Land' and I am now doing some catch up on my SOTS.
THe First thing I have done is modified the Stern Planking, by using 2 part filler and tapering in the First Planking to give a smooth transition and allow me to Second Plank right to the back of the Stern Post with a finished width of 4mm. Both sides of the Lower Hull were then finished with the Maple Strip in Full lengths. I do not want a painted finish as I find the natural wood more pleasing to the eye, I also feel that this is a reasonable representation of whatever 'stuff' they were using as a protective layer below the water line.
Having then added the Keel Pieces, it became necessary to have some kind of Stand. I played around with some Walnut for a Cradle Stand, but in the end settled for a very simple Stand made from Balsa, which is just a slot for the Keel and allows the flat bottom of the Hull to sit level. As this is very soft it also avoids any scratching of the Maple. It is also very forgiving to the surface it is sitting on (such as my shiny new 'AirPrint' printerLOL)
#88 Posted : 28 August 2013 17:14:56
Hull looks great Cool
J
KobusBeukes
#89 Posted : 28 August 2013 17:20:44
Hi Court Orchard
The maple planking of the hull looks stunning!Drool Nigel's build convinced me to go the maple route and now yours has confirmed that that will be the route for me! Love Love the maple planking!
Kobus
Current Build
#90 Posted : 28 August 2013 22:05:58
BigGrin Looks the bizCool
court orchard
#91 Posted : 28 August 2013 22:39:25
KobusBeukes wrote:
Hi Court Orchard
Thanks KobusThumpUp
court orchard
#92 Posted : 28 August 2013 22:40:29
J
Thanks JaseThumpUp
court orchard
#93 Posted : 28 August 2013 22:41:45
Thanks Andy, looking forward to your San Trin buildBigGrin
NMBROOK
#94 Posted : 28 August 2013 22:46:42
Welcome back to the 'shipyard' Andy.The blended stern looks brillCool Cool
Kind Regards Nigel
court orchard
#95 Posted : 28 August 2013 22:55:37
Next I added the Red 'Go Faster' Stripe. I didn't want anything too Red or too gaudy so after trailing a few finishes, I settled for a Dark Maroon, which comes in a Rattle Can by Canbrush. It is a gloss finish, but as I will be applying a Matt or Satin Varnish over it, this will disappear. It has also come out a little darker than in the photo, than it is in reality.
Then I added the Gun Whales for these I used 5x2mm Lime Wood which I sprayed Matt Black. I found it too difficult to fix along the swept edge of the stripe and curve around the Hull in a single length, so I ended up fitting them in sections and fixing with pins which i pushed below the surface. After a little filler, sanding and a touch up with the Matt Paint it now looks like a single piece again.
NMBROOK
#96 Posted : 28 August 2013 23:09:32
Impeccable work AndyLove The stripe will look spot on when matted down.
Kind Regards Nigel
#97 Posted : 28 August 2013 23:22:21
Look Fab Andy and so nice to see you back building again.... Cool Cool .. Have to say we have missed you.... Cool Cool
Marcel
#98 Posted : 29 August 2013 02:18:31
Just loving it.Love Drool
court orchard
#99 Posted : 01 September 2013 10:41:25
Kind Regards Nigel
Thanks NigelBigGrin
court orchard
#100 Posted : 01 September 2013 10:47:12
Thanks Alan, it's good to be back. I've got a lot of catching up to do after my enforced and extended sick leave. Still it feels great to be relatively pain free and off the 'Zombie' meds. Love Laugh BigGrin
10 Pages «<34567>»
This page was generated in 0.256 seconds.
