162 Pages «<8081828384>»
#1621 Posted : 27 August 2013 19:44:01
MWG wrote:
Hi Alan very nice job! Kind regards Mike
Thanks Mike, appreciated.
#1622 Posted : 27 August 2013 19:45:16
Hans wrote:
Good looking deck there Alan. Well done.
Thanks Hans, thanks for looking in.... Cool Cool
#1623 Posted : 28 August 2013 23:34:10
Short update, at long last I have finally finished laying the deck planking.... also took the opportunity to remove the ears on the central deck section so I was able to plank straight over to the edge of the bullworks... Cool Cool .. The slow part of this process was not the laying of the planks but more to do with preparation, especially as each plank was cut, sanded smooth including the edges followed by give each 3 coats of stain... Could also say I was being fussy with the planks I was choosing to apply to the deck trying to make sure I kept a used like look.... very pleased with how it turned out and the pics do not do it justice... Cool Cool .. Tomorrow its down to cutting the mast holes, trimming the hatchways and make a start on the treenailing... Will post more pics then.... Cool Cool
Happy building all,,,,
Admiral Anti Spiral
#1624 Posted : 28 August 2013 23:52:26
Ofcourse beautiful planking again alan, great work!BigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1625 Posted : 28 August 2013 23:54:52
Thanks Admiral, am getting the feeling she is really coming together now... having to reign in my eagerness to rush it.... must be patient.... LOL LOL
NMBROOK
#1626 Posted : 29 August 2013 00:38:44
The deck looks the 'muts nuts'(didn't want to be in bother using the other versionLOL )Alan.Very,very impressive,well worth the time and effortCool Cool Cool .I presume you will be using 1mm gratings.Before doing any additional work around the hatches,I would be tempted to suss out your grating layout to suit the different gratings.It may be a case of enlarging the holes slightly to work with the different gratings so you don't end up with half a hole scenario.
Kind Regards Nigel
#1627 Posted : 29 August 2013 00:50:32
Kind Regards Nigel
Hi Nigel and thanks for the very supportive comments, most appreciated... Cool Cool .. You are correct of course, I fully intend to change the gratings to 1mm and got a feeling each hatch will take at least 3 grating kits... Glare Glare .. You have now given me food for thought, so much so I'm not going to trim the hatches yet, not until the gratings are ready to fit...Cool Cool .. Got a thought in my head to actually make up the gratings and actually fit the gratings to the grating surrounds first and when happy then fit to cover the hatch holes....Cool Cool .. Will have a think and a look at that idea..... Thanks again for the heads up on that one..... Cool Cool
Marcel
#1628 Posted : 29 August 2013 02:05:05
Love Love Drool Crying Love
Sovereign of the Seas
#1629 Posted : 29 August 2013 22:45:46
Thanks Marcel, nice to see it left you speechless.....LOL LOL LOL Flapper Flapper LOL LOL ... Appreciated...
#1630 Posted : 29 August 2013 22:57:17
Started this evening by cutting out the mast holes on the decking, hatches are being left until I come to do the gratings...Cool Cool .. Made a start on treenailing the deck.Crying Crying .. first thing I did was to drill the treenail holes using the trusty Dremel and a .35mm drill, ensured the drill went through the deck ply underneath the decking strips...Blink Blink Using .3mm monofilament fishing line, coated the end with some PVA and used tweezers to push the line into the drilled hole ensuring it went through the decking strips and the ply underneath...Cool Cool;.. Before the glue had a chance to get hold snipped the line as close to the deck as possible. Finally using a damp cloth pushed the line flush with the deck and removed any excess glue.... Happy with how it looks and it doesn't look over scaled....don't think the pics show it too well... Will carry on with it tomorrow but may be into the weekend before its finished.... Cool Cool
Happy building all
NMBROOK
#1631 Posted : 29 August 2013 23:06:10
Very nice work AlanCool I am wary of using fishing ling for treenails because it doesn't sand well,but your technique gets around that.
Kind Regards Nigel
#1632 Posted : 29 August 2013 23:18:34
Kind Regards Nigel
Thanks Nigel, I was aware fishing line doesn't sand too well so would only really use it where I know you can drill and pass it all the way through.. Wouldn't use it anywhere else apart from decking.....Cool Cool
claret
#1633 Posted : 31 August 2013 10:18:16
Hi Alan,
Stunning workDrool Drool Drool
Planking looks fabulous!
claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1634 Posted : 31 August 2013 10:35:40
claret wrote:
Hi Alan,
claret
Thank you Claret, it's a time consuming process but I think the results make it all worth while... hopefully finish the treenailing of the deck today... Cool Cool
budgie
#1635 Posted : 31 August 2013 10:44:04
BigGrin Trenailing looks great AllanDrool
Thought about that myself after seeing Magpies build of Surprise but could only find clear and green coloured fishing line at local shops LOL so back to cocktail sticks for meLOL
or I will need to check out internet
#1636 Posted : 31 August 2013 11:17:49
Hi Budgie, I got mine on Ebay where you will find a wide variety to choose from... Hope it helps..
#1637 Posted : 31 August 2013 11:48:47
Hi Alan,
Must say top work your with your Trenailing and decking.
Regards Trev.
#1638 Posted : 31 August 2013 13:54:50
tf64 wrote:
Hi Alan,
Regards Trev.
Thanks for looking in and the kind comments Trev, appreciated... Must say I have been following your Vic build and simply love all the small details you have been adding.... Thanks again...Cool Cool
#1639 Posted : 31 August 2013 22:15:23
Finally finished trenailing the decking. Have also given the deck a coat of clear matt varnish and will give it another coat tomorrow...Cool Cool
#1640 Posted : 31 August 2013 22:18:32
Started work on fitting the forecastle and quarterdeck. First thing to do was to remove the front 2mm of the forecastle deck to compensate for the bulkhead planking, did a dry fit and see I have a little little more to do but almost there.... Cool Cool
Guest (12)
This page was generated in 0.634 seconds.
