162 Pages «<8182838485>»
#1641 Posted : 31 August 2013 22:28:12
Did a dry fit of the quarterdeck but everything look out of line, meaning the mast hole and the hatchways...Mad Mad Mad .. Started to do some checking and drew the line down the centre of the quarterdeck and low and behold found everything was about 2mm out to starboard... Cursing Cursing .. a badly made piece than now needs some work to rectify the problem.... Here are the pics detailing the problem.. Will now have a think about how to rectify the problem but know it cannot remain as it is so moving the mast hole and hatchways is the only answer I can think of.... Mad Mad .. Any further ideas would be most welcome.... To those following on behind double check to make sure everything is central on these decks.... Cool Cool
Happy building all
#1642 Posted : 31 August 2013 22:41:42
Ah Alan! what a rotten trick! Am I right in thinking that there are no actual plans of the SOTS and that all the kits of her are 'sort of' based on her overall look?
If so I think you could get away with just enlarging the mast hole to move it over, I would suppose there is a sealing disk at the bottom of the mast like the Victory has which would cover up the 'oval' shape of the hole, and simply add a 2mm strip to the 'wrong' side of the hatches to make them line up with the other sides. 2mm less hatch width wouldn't be anything to worry about visually and far easier to add a strip to one side than to widen the other side to match!
Best of Luck with it M8
#1643 Posted : 31 August 2013 22:48:36
Thanks for the assist Robin, I am not really seeing as I big problem more of an annoyance considering parts a lazer cut for accuracy.....Blink Blink .. Mast hole will need to be moved 1mm to starboard and hatches up to 2mm... Mad Mad .. After the deck is planked then all mods will at least be hidden... Cool Cool And you are correct, there are no definitive plans so have a little free reign here so as long as everything lines up in the end and looks good to the eye then I'll be happy again.... will start the mods to the quarterdeck tomorrow and post progress..Cool Cool .. Just goes to show it pays to check everything....
Thanks again and regards
KobusBeukes
#1644 Posted : 31 August 2013 22:55:59
Hi Alan
The deck planking looks fantastic!Drool
Know you will find a good solution for us to follow with the hatching and the out of place hole!BigGrin
Kobus
Current Build
#1645 Posted : 31 August 2013 22:57:00
BigGrin Hi Alan
If I were you I would get in touch with C/S to get a replacement as its a faulty part, the other way to do it is to do as Robin sugests, I presume the decks will be planked and therfore hide any mods made
#1646 Posted : 31 August 2013 23:01:17
BigGrin Hi Alan
Thanks Andy, always great to get your advice... I did consider getting in touch with C/S but we could be looking at 4 weeks for the replacement so think I will just hold off on that option for a little while yet... Cool Cool .. As the deck is to be planked it will hide any mods I make and in this instance I believe it can be rectified without too much problem, a hinderance and annoyance more than anything...Cool Cool .. If that fails tomorrow then will get in touch with C/S on Monday for a replacement issue.... Cool Cool .. Thanks again...
#1647 Posted : 31 August 2013 23:02:43
KobusBeukes wrote:
Hi Alan
Thanks for those kind words Kobus, appreciate you looking in once again... Cool Cool .. As for the solution, will post tomorrow how I get on whether it works out or not..... am confident it can be fixed....Cool Cool
#1648 Posted : 01 September 2013 00:42:56
Just goes to show the calibre of members we have on this forum... It looks as if I don't have to do any modifications to put the quarterdeck right as I now have replacement parts being sent to me by a member who doesn't need them.... A huge thank you to the member concerned, this forum and the members within are the best....Cool Cool
Marcel
#1649 Posted : 01 September 2013 08:34:52
I am to feel glad to be behind the build as of the rest of the world. I have emphathy for you wanting a perfect look and to recieve junk for good money spent.
Overall I Drool over your skills. I thought of byuing the ply and cut it yourself. We need to make an official complaint about the bad products we recieve from the suppliers.
Marcel
Sovereign of the Seas
#1650 Posted : 01 September 2013 08:54:42
Marcel
I think your term 'junk' is a bit strong, yes you should get faulty parts replaced quickly but the. Vast majority of parts are supplied as intended and generally the quality of parts in the DeAg part works is very high. Manufacturing slip ups happen it's a fact of life. If every set being supplied was incorrect you may have a point about the complaint, but this is just a genuine mistake.
#1651 Posted : 01 September 2013 09:14:24
Marcel
Hi Marcel, I can see where you are coming from but in all honesty I couldn't class the items received on this build as junk, far from it. So far I have been impressed by the quality of the goods and yes, just like all other kits there will be some parts that have some faults with them but for me this only adds to the challenge of building, where if something is not right then put the thinking cap on to see if it can be put right.. On the occassions I have had to contact C/S here I have found them to be very helpful even if it takes 4 weeks for replacement parts to arrive... The fault on the part here is I feel is not serious and can be fixed.... Thanks again for looking in, appreciate your comments as always... Cool Cool
#1652 Posted : 01 September 2013 10:01:30
Hi Alan,BigGrin
Watching with interest and glad you pointed out the error you encountered.
Although I am a stretch behind (still boxwood planking Bored ), I pulled the part from my stash and checked it.
My part is not as far out as yours, the hatches are spot on and the mast hole out by 1mm.
The thing that worries me is that I didn`t check the first deck with the mast hole in it, so it could have been that when I had fitted all the decks I may not have been able to get the mast upright, or worse still not get it in at all.
I can see I`m going to have to check the mast for plumb as each deck is fitted and adjust if required.
Many thanks for the heads up on this one, it`s made me think a bit more, rather than take it for granted that everything is spot on.
Keep up the good work.Drool Drool
court orchard
#1653 Posted : 01 September 2013 10:26:26
Great work Alan, up there at the 'sharp end' of the build, it's really useful to have an early warning about these potential hiccups and lots of ideas about solutions should we encounter any of these little problems.
I have to agree with Jase and Yourself, the quality of parts has been very good and certainly as good, if not better, than other wooden kits I have built. Plus of course DeAg will replace anything, without a quibble.
claret
#1654 Posted : 01 September 2013 16:20:46
Hi Alan,
Sorry to hear of the 'problem', but I am confident you will over come it.
I am amazed at the quality of the parts overall, and it throughs you when you hit a snag like this.
The builds is looking as stunning as ever.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1655 Posted : 01 September 2013 21:35:11
Hi Alan, well spotted, I will check my parts tomorrow. Kind regards Mike
court orchard
#1656 Posted : 01 September 2013 22:28:08
Just checked mine and it's spot on, so it looks like it isn't a general problem.
Thanks for the heads up thoughThumpUp
#1657 Posted : 01 September 2013 22:38:15
delboy271155 wrote:
Hi Alan,BigGrin
Thanks Derek and I think you are right, best not to take anything for granted that everything is spot on, far better to check now than to find its an even bigger problem later on.... Cool Cool ..
#1658 Posted : 01 September 2013 22:41:11
Thanks Andy, appreciate you looking in and happy to hear your parts don't suffer the same problem as mine, think I just got a little unlucky here but problem is now resolved due to a kind benefactor on this forum.... Cool Cool Great to see you back with us again....
#1659 Posted : 01 September 2013 22:42:42
claret wrote:
Hi Alan,
Claret
Thanks Claret, happy to say its not a problem any more.... Cool Cool
#1660 Posted : 01 September 2013 22:44:05
Thanks Mike, better to be safe than sorry.. hope yours are ok.... Cool Cool
Guest (8)
This page was generated in 0.356 seconds.
