Steam powered traction engine? Options
Phil berrisford
#1 Posted : 03 September 2013 21:33:29
Rank: Beginner Level 1
Something like the Markie engines but in instalments because 3 grand is a big wedge to pay in one go
#2 Posted : 03 September 2013 21:41:38
A nice choice and would love to see a nice showmans engine, but Partwork companies tend to be very nervous about introducing self assembly live steam models to the masses, for obvious reasons..
Phil berrisford
#3 Posted : 03 September 2013 23:04:27
Thats a good point, maybe they could issue it with a warning or age limit.
#4 Posted : 03 September 2013 23:16:56
Age limits tend to make the underaged want it even more LOL
#5 Posted : 03 September 2013 23:24:50
I believe also that there are laws that say the boiler has to pass inspections for h& safety reasons.
Phil berrisford
#6 Posted : 03 September 2013 23:29:57
I never knew that, not looking good for a traction engine subscription then is it ha ha. It is a shame though I've always wanted to build one but cant really afford a kit outright
Tony C
#7 Posted : 04 September 2013 21:24:23
A few years ago,Winson engineering offered various steam powered kits. All the boilers were built, tested, and certified by the manufacturer. So it could be done, and possibly at a reasonable price, if enough subscriptions were obtained.
Phil berrisford
#8 Posted : 04 September 2013 21:31:38
Id subscribe to it in a heartbeat and im pretty sure a lot of others would do to
Tony C
#9 Posted : 14 September 2013 21:30:11
Something I should have mentioned in my last post, it was virtually impossible to get any of the models to run; burning coal, or wood. Butane is a suitable fuel source. But, having the knowledge to do this safely; is another story.
Tony C
#10 Posted : 14 September 2013 21:40:36
Phil, if you really want to build a traction engine, can I suggest model Engineer magazine, or perhaps contact one of the supply companies for model engineers.
Phil berrisford
#11 Posted : 15 September 2013 01:55:44
I will look into it when i get back from afghan as i really want to build one as for getting them to run my uncle said he had the same problem after he brought his one years ago already built from a steam fair, he tried twice to get it to run and he said he could not get the heat it needed so i gave him some heximine tablets and they worked brilliantly
Tony C
#12 Posted : 15 September 2013 22:01:07
Phil, Come back safely. I don't know what or any machine tools you have access to, you can buy rough castings which you machine yourself, or you can get the finished items; at a greater cost. I would suggest you buy the largest scale model you can comfortably afford. It really is a case of the bigger they are, the easier they steam.
#13 Posted : 16 September 2013 20:58:46
Phil, when you get back you should check this place out which has a load of Tractions engines and models amongst the rest of the exhibits..
http://www.flowerofmay.com/museum/museum.html
Stay safe mate..
SennaMentalMe
#14 Posted : 16 September 2013 22:04:21
Ditto those sentiments Phil - keep your head down and come back safe and sound please?! ThumpUp
mark 2
#15 Posted : 16 September 2013 22:05:05
Hi Phil.
When you come back this link might help you out.
http://www.steamtractionworld.com/burrell2.htm
Best regards.
This page was generated in 0.139 seconds.
