Issue 117 Boomkin Stay Ropes Options
GilShapley
#1 Posted : 05 September 2013 23:10:35
Can someone please clarify how to add these ropes.
The instruction and build diary state that they should be tied to the end of the stays, but the photo in the diary seems to show the stays threaded through the block which is on the boomkin stay.
Which is correct????
The picture from the build diary is attached
Current Build:-
CMB
#2 Posted : 06 September 2013 01:23:45
Hi,
The black thread is tied to the end of the boomkin as per the instructions,the block is used later in the rigging.Have a look at pictures 5 & 6 in the same issue. Hope this helps,
CMB
GilShapley
#3 Posted : 06 September 2013 11:04:37
Thanks for that. "RTFQ" springs to mind. Next time I will look on the next page
Confused Confused Confused Confused Confused
Should finish 117 tonight. That only leaves 3 more to go
All I have to do then is build a display case to show off my Victory
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
This page was generated in 0.041 seconds.
