Proxxon FSB240/E MINI-DRILL AND ACCESSORIES. Options
#1 Posted : 11 September 2013 15:51:56
Having worn out my old minicraft mini drill. I set about looking for a reasonable replacement.the specs are as follows.
Multiple uses; cuts, sands, polishes and grinds, etc.
0.3-3.2mm keyless chuck
Variable speed
Two inset rubber body grips
Permanent magnet motor
Maximum motor power 100W
Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories
Not cheap, but you get a lot of drill for the money.If used with the drill stand you open up loads of possibilities,like lathe, milling,cutting. engraving and loads more jobs.
karl1113 attached the following image(s):
#2 Posted : 11 September 2013 15:59:29
the main reason I chose this model is because it had bags of torque,no batteries to worry about just plug it in,also keyless chuck,no collars to mess with,
variable speed, and takes drill sizes from .03mm - 3mm. which is a large range.
der Gohfelder
#3 Posted : 11 September 2013 22:13:12
Hi!
During the years I´ve bought nearly the whole Proxxon program, these tools are really good! Of cause the mini drill is the most used BigGrin
Regards, Bernd
This page was generated in 0.205 seconds.
