Just a quick update of this... been doing a bit of work and searching and finally came up with a cheap alternative to the expensive lighting kits out there..The LED kit arrived this morning and this is just a test i've uploaded so you can see the effect. There is still a lot to be done but video below will show the effect.... Into Darkness Bussard EffectSpence
Looks the business Spence
Warthog wrote:Just a quick update of this... been doing a bit of work and searching and finally came up with a cheap alternative to the expensive lighting kits out there..The LED kit arrived this morning and this is just a test i've uploaded so you can see the effect. There is still a lot to be done but video below will show the effect.... Into Darkness Bussard EffectSpence Looks very good! Would you mind sharing what lighting kit(s) you went for? I'm in the market for a cheaper way to light the Enterprise. I'll look in to doing my own lighting on other models when I have more time. Do you have any progress on your kit? Simon
Hi Simon, Due to other commitments I've not been able to do a great deal to this but over time I have been collecting a multitude of LED's and circuit board kits. Also the orbital drydock masks arrived yesterday and micro motors for the bussards... I will put a list and take photos soon Spencer
Warthog wrote: Hi Simon,
Spencer
Ooooh, look forward to them, thank you. Simon
Hello Spencer,
How's the model coming along? Have you found any time to do any?
Simon
Hi Simon I'm on holiday at the moment and will be back tomorrow so I will put a few pictures up of some of the progress.. Spencer
First update of this build as now I have everything I need... First off is getting a good light block on some of the sections I will be lighting.. I did one coat of grey primer and 2 coats of black, this will then be followed by one coat of white to help reflect the lighting. Parts of the Naccels have been cut out to allow a small amount of light through on the insides... More updates to follow soon! Warthog attached the following image(s):
 Hi Spencer your pic's don't compute Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I'll re-do them
Nice to see this up and running “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Going to be a slow one mate but worth taking the time on
