25 Pages «<1819202122>»
Claret's SOTS Build Diary Options
claret
#381 Posted : 17 September 2013 10:25:58
Hi Hans,
Thanks for looking in, and you nice comments.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
NMBROOK
#382 Posted : 17 September 2013 12:31:56
Hi Claret
I can only reiterate what I said before,very,very,very neatCool Cool Cool Cool Cool
Kind Regards Nigel
claret
#383 Posted : 17 September 2013 12:40:33
Hi Nigel,
Thank you.
It is quite a slow process. Painted them all individually, and black marker along the edges. Aliphatic glue used to glue them down, and I use a piece of dummy gun support longer than the 60mm plank to butt up against and push onto the last row of planks to make sure there is a tight fit.
The Amati plank cutter is a godsendBigGrin
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#384 Posted : 17 September 2013 13:58:57
Admiral Anti Spiral
#385 Posted : 17 September 2013 14:09:26
Lovely work claret, that planking is going to look greatBigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
claret
#386 Posted : 18 September 2013 08:54:34
Hi Steve & Admiral,
Thanks for looking in and the nice comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#387 Posted : 23 September 2013 08:58:07
Hi,
A lot more work done this week, finished off the planking and tree nailing. The treenailing was done by drilling 0.4mm holes and threading 0.3mm fishing line through and pushing flush with the deck. I did not have black line so used permanent black marker to colour the ends before inserting. tedious job, but pleased with the results.
I also added the supports for the forecastle and quarter decks, plus the dummy cannon supports in between treenailing to relieve the monotony of the work.
finally gave the deck a coat of matt clear varnish.
pics below.
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#388 Posted : 23 September 2013 11:49:33
BigGrin Stunning work Claret rgd MartynBigGrin
claret
#389 Posted : 23 September 2013 15:16:15
Thank you Martyn.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
KobusBeukes
#390 Posted : 23 September 2013 19:24:08
Hi Claret
Looks stunning! Love
Kobus
Current Build
#391 Posted : 23 September 2013 21:56:09
Lovely work Claret, your build is doing you justice for all your efforts on producing a very clean build..... Drool Drool .. Very well done....
NMBROOK
#392 Posted : 23 September 2013 22:34:09
Excellent work on the deck ClaretCool Cool Cool
Kind Regards Nigel
claret
#393 Posted : 25 September 2013 13:40:15
Hi Kobus, Alan & Nigel,
Many thanks for the kind comments and looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#394 Posted : 25 September 2013 13:42:53
claret
#395 Posted : 26 September 2013 09:00:37
Thanks Steve.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#396 Posted : 29 September 2013 18:34:14
Beautiful work there Claret, something to aspire to. Well done
claret
#397 Posted : 29 September 2013 21:48:19
Many thanks Hans.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#398 Posted : 29 September 2013 21:53:25
Hi,
An update on my progress.
I have glued the forecastle and quarter deck bulwarks.
I also fitted one of the grate openings. Because I used 1mm gratings which are 33mm square, I decided to mod the area and use the walnut stained planks to cover the grating joints. Outcome below:
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
KobusBeukes
#399 Posted : 29 September 2013 21:59:18
Hi Claret
The gratings look stunning!Drool
How many sets of the 1mm (33 mm) gratings would be required to cover the required areas? Need to source it in SA to see if its available, otherwise need to look at the UK to order some!Crying
Kobus
Current Build
#400 Posted : 29 September 2013 22:15:50
Beautiful work Claret, think the 1mm gratings look so much better and love your mod.... Cool Cool .. Well done....
This page was generated in 0.396 seconds.
