Best Glue Options
#1 Posted : 19 September 2013 20:43:55
BigGrin Hi all just wondering wot the best glue to use for gluing the window parts to the stern . Thanks MartynBigGrin
NMBROOK
#2 Posted : 19 September 2013 21:59:57
Hi Martyn
Epoxy is by far the best adhesive for the job.You need to roughen the back of the casting a little and I scratch a small area in the middle of where the casting sits on the hull.For awkward castings I have used epoxy and left a couple of corners without epoxy and used thick cyano on these.The cyano holds the casting in place while the epoxy cures properly.
Kind Regards Nigel
#3 Posted : 20 September 2013 07:24:08
BigGrin Thanks Nigel of to get some Epoxy rgd MartynBigGrin
This page was generated in 1.048 seconds.
