162 Pages «<8990919293>»
#1801 Posted : 20 September 2013 15:06:38
Hi Allan.
Realy superb job on your vanishing.
shes looking realy fantastic. ian Cool Cool BigGrin Drool
#1802 Posted : 20 September 2013 22:19:44
ian smith wrote:
Hi Allan.
Thank you Ian, appreciate your very kind words..... Cool Cool Loving this build, challenging but so so rewarding.... Cool Cool
#1803 Posted : 21 September 2013 22:38:20
Started issue 48 by making up the cannon ball racks, a little fiddly but got there in the end... Also cut the side of the racks to an angle to take the shape of the bullworks and give a better fit... Cool .. Not leaving the racks in their natural colour but intend to stain once they are set... Blink Blink
Moved onto painting the bulkheads black on the forecastle and quarterdeck, first gave them a coat of undercoat... Lastly, moved onto staining 2 strips of 1x3mm basewood walnut, two coats and fitted the strips along the side of the gunports.. Tomorrow will move onto fitting and filling the cannon ball racks.... Cool Cool.. Heights of the bullworks and bulkheads have yet to be finalised and will do that at a later date...
Happy building all..
#1804 Posted : 22 September 2013 08:03:59
BigGrin Looking good Alan now all the fun bits start BigGrin Happy building rgd Martyn
#1805 Posted : 22 September 2013 10:47:59
Thanks Martyn and yes, we are getting to all the fun and interesting parts of the build.... am sure they will all be challenging in their own ways but am looking forward to it.... Cool Cool
#1806 Posted : 22 September 2013 10:53:51
Short update, have now made a start on the deck planking... Decided to stick to the measurements I used for the lower deck and marked lines across the deck at 47mm apart, also decided to leave my options open regarding the hatches on the higher decks, whether to have open or closed hatches therefore am going to plank the whole deck rather than just the centre section... Blink Blink .. Settled on using Tammy planks 1 x 4mm, each plank cut into 141mm lengths. Sanded each plank including the edges before giving 3 coats of light oak stain, each coat darkened the plank just a little... Caulked each edge with permanent marker and because it was stained first the bleed is just about non existent... Very happy with how it looks and will continue with it tomorrow.... Cool Cool. Will treenail when the deck is laid....
Happy building all....
What an absolutely brilliant build you have. Could I ask please what the thickness of the 1 x 4 deck planks you used was.
Kind regards
Tony
#1807 Posted : 22 September 2013 11:03:30
Kind regards
Tony
Hi Tony and thank you for those very kind comments... For the decking planks I used Tanganyka Strip 1mm thick by 4mm wide. Available from Connwall Model Boats in lengths of 1 metre.... Hope this helps.. Cool Cool
#1808 Posted : 22 September 2013 11:07:13
Great looking build Alan!! ThumpUp
#1809 Posted : 22 September 2013 11:13:43
Kind regards
Tony
Many thanks for that -very helpful indeed.
Would also like to thank you for your guidance on the query I raised over staining the beak section.
Had good advice from many of the forum members but settled on your idea of using left over sapelle wood. Very happy with the end result.
Many thanks again Alan for sharing your build, skills and ideas .
Kind regards
Tony
#1810 Posted : 22 September 2013 12:34:24
Kind regards
Tony
Kind regards
Tony
Thanks again Tony and am so pleased you found my tip to your liking... Its what the forum is all about, passing on tips and ideas through the use of diaries... I try wherever possible to read all the ship diaries, it is where most of my inspiration comes from.... Happy to be of assistance any time you feel you need it.... Cool Cool
Best regards
#1811 Posted : 22 September 2013 17:45:21
Thanks Jonny, thanks for taking the time to look in and for your gracious comment.... appreciated....Cool Cool
#1812 Posted : 23 September 2013 04:54:03
Great Job AlanBigGrin all the best Mike
claret
#1813 Posted : 23 September 2013 08:59:50
Hi Alan,
Lovely work.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1814 Posted : 23 September 2013 21:58:48
Thanks Mike, appreciate you looking in...
#1815 Posted : 23 September 2013 21:59:51
claret wrote:
Hi Alan,
Lovely work.
Claret
Appreciate your kind comment Claret... thanks... Cool Cool
#1816 Posted : 23 September 2013 22:07:29
Progress to date.... stained and fitted the cannon ball racks, much happier than leaving them in their natural colour... Cool Cool .. Started work on painting the stern ornamentation by removing the burrs and mould lines, giving the pieces 2 coats of primer... Moved onto trying various gold paints but on wood, finally settled on a metallic antique gold and for me is more in keeping with the period of the ship.... unfortunately, the photo's don't do the colour justice and even after several attempts could not get a photo to show the metallic effect..... Really like how it looks.... In between painting I made a start on the ships bell housing, base glued together and using a fine sanding block rounded the edges.. Finished by giving it the first coat of walnut stain.... no where near the finished product Cool Cool ..
NMBROOK
#1817 Posted : 23 September 2013 22:43:32
Coming on well AlanCool Cool Cool Cool
Kind Regards Nigel
#1818 Posted : 23 September 2013 23:36:46
Looking great there Alan Cool
Looking at that metallic gold effect, it might be worth trying some experiments with a dark brown or black ink wash which would give the mouldings an increased depth or 3D effect and also add to the 'age' of the look. (That didn't come out right but you know what I mean!Blushing ) Rather than try it on the actual mouldings, you could try painting some cheapy plastic soldiers (old airfix types) in the gold and try ink washing them!BigGrin I normally use the Citadel acrylic inks but I've found the new Humbrol Enamel Wash to be really good, especially on metallics!
Keep it up! Cool
#1819 Posted : 24 September 2013 00:01:46
Kind Regards Nigel
Thanks Nigel....
#1820 Posted : 24 September 2013 00:06:55
Keep it up! Cool
Thanks Robin and thanks for the tip.... Like I say, the photos really don't do the finished pieces justice but at the same time I really like your idea.... I went for the antique gold paint because the others just appeared to be a little to garish for my liking and unlike the photo shows its not as yellowish as it appears.... Cool Cool .. Do want to just age it a little so have now ordered some Enamel wash as you suggested and will do a little experimentation on some plastic figures I have.... Judging by what I have seen on youtube then think it will give me the appearance I really want.....Cool Cool .. Thanks again for the input....
Best regards
Guest (11)
This page was generated in 1.074 seconds.
