Coating Plywood Options
andysod
#1 Posted : 29 September 2013 23:52:00
Hi all, I was wondering if anyone had any thoughts on giving the plywood part of the model a coat of pva or similar when built as far as end of stage 8, I wonder whether it would be beneficial in hardening the wood and making for a stronger framework. cheers andy
#2 Posted : 30 September 2013 00:46:59
BigGrin Hi Andy
Coating the ply with PVA wont really add any strength or harden the wood and it would still be pourous afterwards. Varnish or a laminating epoxy would seal the wood but again not add strength.
I am not building this model but i suspect as the parts to the fuselage are added it will stiffen up considerably and may not need any hardening up
Hope this helps
#3 Posted : 30 September 2013 08:50:07
I agree with Andy, you wont need to do this as the frame will become rigid as you build it. The weak points will be the joints so make sure you are fixing these with Aliphatic glue as it is stronger than PVA. You could also run a beed of glue up the joints for strength but be sure it will not be fouling later construction.
As a general rule the instructions will have considered everything you need to do to ensure the construction is robust.
andysod
#4 Posted : 30 September 2013 13:40:28
Thanks Andy and Jase, Ill leave it alone, I have bought some Aliphatic glue Jase, I bought the yellow one "Aliphatic Wood Glue Waterproof (1016)" thanks for replies, Andy
kwakermad
#5 Posted : 30 September 2013 14:17:42
Jase I have never heard of this type of glue before so a quick search of my on stop shop, Ebay, and there are several options Confused . Which one do you recommend?
Bob
Builds in progress
1/12 Spitfire (Deagostini)
1/8 McLaren (Deagostini)
1/16 Stuka (Hatchete)
1/16 Zero (Deagostini)
#6 Posted : 30 September 2013 14:29:33
There is not a lot of differance i dont think but I am using
Aliphatic Rapid Glue Giant 500ml
http://www.cornwallmodel...ues%2ehtml%23a1016#a1016
kwakermad
#7 Posted : 30 September 2013 14:36:02
Thanks for the heads up
Bob
Builds in progress
This page was generated in 0.247 seconds.
