4 Pages 123>»
HMS Naiad - WW2 Dido class cruiser Options
Ken
#1 Posted : 11 October 2013 15:32:39
Hi All
After reading what has been done on this site I decided to try a conversion of a paper/card model into wood/plastic. Looking at what's available, finally decided on a GPM Kit of HMS Naiad for the various reasons
Size - its 780mm long x 80mm beam at a scale of 1:200
Photo etch and turned gun barrels are available from the same supplier
Laser cut handrail is also available
All frames and keel parts are in 2mm card on the original but can only get 1.5mm ply so will have to work from centrelines and adjust accordingly
For planking going to use wooden stirring sticks that can be bought cheeply from the internet (If it is not successful then not much lost)
After copying all relevant parts and sticking to ply they were cut out and the frames reduced by the thickness of planking.
Ken attached the following image(s):
Ken
Completed Models
IJN Yamato, Hachette Titanic, Del Prado Victory, Tamiya 1/16 RC Pershing Tank, HMS Naiad, HMS Prince of Wales, Admiral Hipper, Tirpitz, USS North Carolina
[Current Build
USS Enterprise CV6
budgie
#2 Posted : 11 October 2013 20:08:31
BigGrin Nice start Ken will be following with interest
Got this one in my bottom drawer (GPM) as was attracted to her after seeing an article in a mag
Drool She's a nice length but a bit on the skinny side
BigGrin Will look fwd to your next post
#3 Posted : 11 October 2013 22:54:46
Lovely start Ken, will be following with interest... Cool Cool
Ken
#4 Posted : 12 October 2013 10:42:15
Hi Budgie, Gandale.
Thanks for your comments. Realised that just a ships name won't mean much so -
Ken
Completed Models
[Current Build
USS Enterprise CV6
#5 Posted : 12 October 2013 11:16:17
Looks an interesting build Ken Cool
#6 Posted : 12 October 2013 12:00:47
Hi Ken, good luck with this interesting buildBigGrin Kind regards Mike
Foz
#7 Posted : 12 October 2013 15:19:24
Hi Ken
Looks a very interesting build you have started. Look forward to the progress.
Foz
Ken
#8 Posted : 12 October 2013 17:48:04
Hi All
Thanks for the comments.
Glued the waterline parts together and pinned to a base board. stuck keel section down and added fillets for support. Will add lower keel when upper section complete.
Ken
Completed Models
[Current Build
USS Enterprise CV6
Ken
#9 Posted : 13 October 2013 20:26:40
Hi All
Hull progressing nicely. Glued frames to waterline section
Ken
Completed Models
[Current Build
USS Enterprise CV6
Ken
#10 Posted : 15 October 2013 14:03:15
Hi All
Started planking the hull. As the timber I'm using is only 150mm long I've added extra wood to the frames where required. For the bow and stern areas I will be adding blocks and shaping to suit
Ken
Completed Models
[Current Build
USS Enterprise CV6
Ken
#11 Posted : 17 October 2013 19:31:11
Hi All
Planking coming along nicely. All prepped for next layer. Will be using 0.5mm and 0.25mm plasticard for the hull plating in rows at about 10mm. This should look about right. Progress so far
Ken
Completed Models
[Current Build
USS Enterprise CV6
#12 Posted : 17 October 2013 23:17:31
Lovely work on the planking Ken, coming together and starting to look like a ship.....Cool Cool
#13 Posted : 18 October 2013 00:26:32
Ken
#14 Posted : 18 October 2013 13:40:42
Hi Gandale, stevie_o.
Thanks for the comments. Enjoying the conversion from card to plastic/wood. Hats off to those that can work with card.
Will be posting more pics as the build progresses.
Ken
Ken
Completed Models
[Current Build
USS Enterprise CV6
Ken
#15 Posted : 20 October 2013 14:19:55
Hi All
Decks planked and hull sanded. Used paper templates to mark portholes and hawse pipes. Drilled oversize ready for next layer.
Ken
Completed Models
[Current Build
USS Enterprise CV6
Foz
#16 Posted : 20 October 2013 16:00:03
Looking really smart Ken. Look forward to your progress.
Foz
Ken
#17 Posted : 20 October 2013 21:31:22
Hi Foz
Thanks for the comment. Looking forward to the next stage.
Ken
Completed Models
[Current Build
USS Enterprise CV6
#18 Posted : 20 October 2013 21:55:25
Coming along very nicely Ken, credit to you....Cool Cool
Ken
#19 Posted : 22 October 2013 21:41:03
Hi All
Started plating the hull. The plates are 10mm deep. This seems to look right compared to photographs. The plastic is stuck down with RC Modellers glue in alternating bands of 0.5mm and 0.25mm plastic.
Ken
Completed Models
[Current Build
USS Enterprise CV6
budgie
#20 Posted : 22 October 2013 22:02:56
BigGrin Hi Ken coming along nicely
Looks better than the card templates which are all even (2d)
Much better the way you have gone (3d)
Will look fwd to next update
4 Pages 123>»
This page was generated in 0.462 seconds.
